Results 1 to 10 of 10
Thread: Flywheel Options
    Flywheel Options
    OK It looks like I am going to go with the Ram HD clutch.
    For you heavy hitters out there running steel flywheels please explain the pros and cons of steel. My car will be 600+ RWHP with an aggressive launch. Just trying to figure out what is best.
    So Cal
    I personally don't like the Steel Flywheels due to the extreme hit it will put on the entire drivetrain. The Aluminum Flywheels have such a softer hit, it is a bit hard to explain. Not sure what type of flywheel you had on the 5.0 of urs, but my Mach1 60' the same with the OEM Steel Flywheel and on a Findenza Flywheel...It just didnt feel so harsh off the line with the Aluminium one, but it bogged down way to easy for my taste.
    If you are running on some seriously prepped tracks, a Steel Flywheel would be the best choice IMHO. An Aluminum Flywheel needs all the HP & TQ to help the minimal inertia it offers compared to a Steel Flywheel. Also, the Aluminum Flywheel seems to be way too sensitive to hot laps...I could bust out 19 runs in 3 hours on a Steel Flywheel and not think twice about it. My Termee's clutch starts stinking if I do a back to back to back run with in 1 hour.
    Both have a PRO & a CON.
    I rather burn up stock clutches VS input shafts....Personally.
    Do you have a 26 spline input shaft?
    I haven't heard of those breaking.
    So Cal
    I will if I snap the Termee's one. I shouldn't, but who knows.
    Mach1's TR3650 only come in 10 splines. Snapped 2 of them, but one held for about 600 runs and the last one held for 400 runs...before It snapped when I got into 3rd gear both times.
    Is your track usually super glued? Famoso is pretty dang glued and I did have a problem bogging last time I was out there with the Termee. Even 5000 rpm launch couldn't hold the disc from slipping on the flywheel.
    Senior Member Venomous Bite's Avatar
    to cool to put it down
    I have a Fidanza in my Cobra, however I have not taken it to the track sense I put it on.
    Quote Originally Posted by Venomous Bite View Post
    Steel or Aluminum?
