Results 1 to 10 of 22
Thread: Need Some Advice On Motor Work!
    Senior Member JoeT's Avatar
    Feb 2007
    N. Phoenix - Az. USA
    As some of you know I have 1980 Trans Am, no booing or hissing please.
    Anyway I had the motor work done on this vehicle at a place called OPM Customs in Tempe to the tune of about 7900 bucks, to make an extremely long story short, the motor has already blown, or at least I believe it has a blown head gasket, milkshake colored oil, which I drained completely a day after it overheated. The shop WILL NOT stand behind their work, so if anyone knows this shop, I do not recommend them! I am also currently in the process of going to small claims court to recoup some of the loss, but there's no guarantee they will pay. Most shops arent know for honesty.
    Anyway, money has recouped a little since getting rid of the Mustang so now I'm trying to put myself in a position to get the Trans Am running again.
    The question is, does anyone know of a shop that is straight up and knows what the hell they are doing? Do they stand behind there work with a written guarantee. Aren't there any shops like the ones I see on Spike TV in Arizona, where they truly seem to care about the cars they work on?
    I'm not a huge mechanic in anyway, I know simple basic stuff but in no way do I know rebuilding of motors, so I'm leaning on the Mustang Club to help me here with some direction.
    The motor currently in the vehicle is not numbers matching as a 1980 TA came with a 301 or 305 motor, I pulled the motor and replaced with a Pontiac 400. Has Ram Air III heads off a 1967 GTO. Has a minor cam and an Edelbrock Performer intake with an Edelbrock 650 CFM carb, hedman headers, only ones that would fit. Other than that I'm clueless. Ran pretty good initially, but I had less than 500 miles on the motor when this blew, and of course the shop says its because I race around in the car. Which is not true, I do not abuse my cars, and especially one that I have about 30k into.
    So if anyone knows of a shop that is capable and competent to handle this please let me know.
    If you read this and own a shop I will require a written guarantee. Im extremely picky, and will go over the car with a fine tooth comb upon dropping off the vehicle to insure no damage is done to the car while in the shop, I will hold the shop responsible for any damage occured while in your possession.
    The car is virtually restored completely except for this motor issue.
    Eventually the goal is to enjoy the car this fall because of the T-Tops and then dump it next year for another Mustang.
    I'm hoping someone has a few ideas, because Im really gun shy now of shops. This restoration of the TA has been an 8 year nightmare. Nobody does what they say they will in the beginning to get the work. They are my best friends initially, then they change on me when they know Im trying to get the best from them. When I try to get them to promise me something they usually start with "Keep In Mind This is a 30 year old car". Which is BS! You spend enough it takes away from the age of a car. Spending 7900 on the motor this car should scream and like it!
    I'm a car guy, so I want maximum effort for the money I put out.
    I also don't want the car to sit in a dirty dusty shop for months. If you cant handle the work please don't apply.
    Any advice or direction I would greatly appreciate it.
    Car does not run currently.
    Feb 2007
    Thought Id toss some photos up.
    Joe, give me a call.
    Call knudsens auto on 19th ave and Cactus. 602 861 2119 Talk to lyle sr. They built my mustang motor and my nova motor and trans, both run like dreams and a good deal as well. He will tell you what you should do or what you could do to save some money but still be a great motor and ask you which one you prefer and give you a price for it. he built my mustang motor from scratch in two days so it wont be there long
    Feb 2007
    Thanks for the 2 recommendations. I have spoken to one already but would like to get more opinions. This is the 2nd time Ive had motor work done on this car and it absolutely must be done correctly this time. So keep the opinions, recommendations and experiences coming.
    Mar 2008
    Phoenix , AZ
    Carmens Inovations located at 27th ave and deer valley. He has been around for over 10 years. When i lost oil pressure in the stang I knew it was internal so I had it towed to him. He went through the motor to make sure nothing was damaged cause I seized the oil pump and gernaded the oil pump drive shaft. Took him 3 days to clean everything out and replace all the needed parts to have me back on the road for less than a grand. This happened about a year and half ago and I havnt had any issues since then.
    93 FOX
    67 'Stang Lover
    Guest
    Joe,
    Sorry to hear about this mess that you are in. This is why I learned how to build my own car's from the ground up including my engine build. I have built 4 Mustang's myself and I love doing it as a hobby.
    However, I can recommend a Speed Shop in Mesa for you. It is called Maximum Horsepower Performance (MHP). They are right next to Loper's Performance Shop on Country Club just south of Main St. The engine builder that works there is Bruce and he built my 9" rearend over at Darryl Smith Racing. He is good and they warranty all of their work. Hope this helps. If you need any more info call me on my cell- 480.200.5606......
    Steve............
    Feb 2007
    Thanks Steve! I'll definitely look at all recommendations, I'm surprised all these car guys aren't all over this for recommendations.
    Whatever I do I'm going to need guarantees from whomever fixes this. I'm leaning towards a crate motor at this point.
    67 'Stang Lover
    Guest
    Joe,
    BTW, nice T/A. If i were you I would keep it. Good luck on whatever you do but you can call me any time so we can talk more. I have been doing this for 25 years and have a lot of connections. I have my '67 Mustang that I built myself and know quite a few people in the 'Business'. Yeah, I thought you would get a lot more responses since most of the guys/gals on here are 'Motorheads'. I hope you have some success though.
    Steve............
    Quote Originally Posted by JoeT View Post
    Senior Member Blackmagic1's Avatar
    Joe, you better come get some ice cream today at the GTG, it'll help !!
