1988 Fox Coupe 5.0 GT - Back On Track - Strip/Show Fox
Jim Ricchezza Is Back On The Scene With This LX Notch1988 Fox Coupe
5.0 Tech Specs
Engine And Drivetrain
Block '72 302, 0.030-inch over
Displacement 306ci
Rotating Assembly Eagle crankshaft and connecting rods, TRW pistons, Total Seal gapless piston rings
Compression Ratio 10.5:1
Camshaft Comp Cams solid flat-tappet cam and lifters
Heads Edelbrock Performer RPM, 2.02/1.60 valves, Trick Flow 1.6-ratio roller rockers, Comp Cams valvesprings
Intake Edelbrock Victor Jr., port-matched
Carburetor Biggs Stage 5 750-cfm
Power Adder Zip, zero, nada
Fuel System MagnaFuel QuickStar 275 fuel pump, Russell Performance braided fuel lines, Holley fuel-pressure regulator
Exhaust MAC 1¾-inch long-tube headers, Dr. Gas cross-pipe exhaust system, DynoMax Bullet mufflers
Transmission Frank Lupo Pro-Formance Transmissions C4, Ultimate Converter Concepts 5,000-rpm stall converter, and transbrake with a B&M shifter and a Ford Racing Performance Parts aluminum driveshaft
Rearend 8.8, welded and braced by Rhodes Custom Auto, 4.88 gears, Moser Engineering 33-spline C-Clip eliminator axles
Photo Gallery: 1988 Fox Coupe 5.0 GT - 5.0 Mustang & Super Fords Magazine
Full Story...
