Results 1 to 10 of 14
Thread: Heads and Cams
    Feb 2009
    Peoria, Arizona
    Heads and Cams
    Need some advice on what cam's to get, ive always been a big fan of Comp Cams, specially their Thumper series, Since ill pretty much have the head taken apart i'd figure why not get it ported and polished, then take a swing by PSR and have them do a tune for it.
    My question is, will new cam's make a noticable difference or would it be wasted money?
    Id say porting heads and the addition of cams would make a pretty big difference. Before you chose a cam you need to ask yourself what you want to do with the car(Street,Strip). Once that is established then Id chose a cam. Comp NSR cams are great, they have two stages. Stage one cams have 214/227 duration @.050 with a 114 lobe separation and would work great on a car that is dd as they will fatten up your torque curve. The stage 2 has 222/235 degrees of duration @.050 with a 115.5 lobe separation and will give you more top end power. The stage 2 cams will have a little better lope to them as well. With any set of cams you go with Id would strongly recommend adding long tubes to maximize the power. It should be said that with either set of cams you should add comp's phaser limiter kit so you dont run into ptv clearence issues. Ive seen this first hand and its not pretty.
    Senior Member Blackmagic1's Avatar
    Quote Originally Posted by Jodaddy View Post
    Sent you a PM
    Member 2nd2nunn's Avatar
    Jan 2009
    PHX
    also keep in mind you will need a set of cam phaser Deletes (not limiters) for any cam upgrade that requires springs. as for the headers i would put you money else where you will see a power gain, unless you are looking for the sound. you may only see a 2-3 rwhp gain thought the mid range and thats about it. The comp stage 3 cams sound absolutely phenomenal and also make some good power.
    Quote Originally Posted by Ernie@PSR View Post
    Thanks Ernie.
    On a 3V engine, when the cam mfg recommends springs, the overwhelming majority of performance shops recommend installing Cam Phaser LOCKS instead of the limiters.
    The cam phasor "rattle" has still been known to occur with limiters. That "rattle can lead to vast part destruction.
    Limiter, locks same kit. Call it what you want, comp calls them limiters.
    http://www.compperformancegroupstore...&Category_Code=
    Quote Originally Posted by HigherPower View Post
    Ethan
    They are two different things.
    Limiters limit travel of the phasors to 20 degrees and the phasors still have to deal with the higher spring pressure and the possible malfunction of the oil pressure and the phasors rattling back and forth can still occur.
    Phasor locks actually lock the cams in one position and the phasor can no longer control the timing of the cam therefore no problems with the phasors malfunctioning.
    Believe it or not, the first run of the 05 3Vs had the phasors locked out because they knew there was a problem.
    Mike, thanks for stopping by today, it was good talking to you. All I said in my first post was that comp makes a limiter kit and I'd suggest using it as do they. But hey what do I know, Im not the super tech.
    Jan 2009
    im glad to see that some one was able to help you
    Senior Member 05mustangman's Avatar
    Jan 2007
    Surprise, AZ
    I would trust PSR with my car hands down. and dan and ernie no that. I plan on doing the cam project soon along with some longtubes. mine will be used mainly just for street on weekends only. so nothing too radical but still pretty awesome. like dan said i think the stage3 comp cams would be awesome.
