Results 1 to 2 of 2
Thread: Help with ignition switch wiring on 67
    Member vin man's Avatar
    I've been having some serious electrical problems with my 67 Mustang. One of my known problems is my ignition switch. The prior owner did a terrible job wiring this thing up and now I've got broken wires. I picked up a new switch today, but need to know what wire goes to which pin on the switch. Anyone have a diagram? If not, can someone look at their switch and tell me the color wires and the corresponding spot on the switch?
    If we use the diagram at the top, you can refer to the posts by their clock position. Looks like there is one at 1:00, 3:00, 9:00 and 11:00.
    If I were to guess, I would say that 1 is the off position, 11 is on, 9 is start, and 3 is accessory.
    Edit:
    I'm starting to help myself. I found this in the electrical diagram at http://midlife66.com/wiring/wiring.html
    Now I need to figure what positions the wires go to....
    Does anyone agree with me that 1 o'clock is B, 3 o'clock is A, 9 o'clock is S and 11 o'clock is C?
    Thanks.
    Found and solved my problem.
