Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
Thread: what shop could help me?
    Jan 2009
    I have a pair of E7s you can have if you need them
  2. #12
    Senior Member ttocs's Avatar
    gilbert
    is the head, different from the heads? I thought the heads were on the top of the cyclinder and had the valves in it?
  3. #13
    Mar 2008
    Phoenix , AZ
    Quote Originally Posted by ttocs View Post
    No there isn't any difference but I would get those heads from dan and put them on your car with new bolts and head gaskets because if you only replace one then you might run into a problem with the old head later in time.
    93 FOX
  4. #14
    gilbert
    I am just a motor idiot, I didn't realize that the bolt was broken in the head I thought it was in the block.
    I had plans on replacing the heads sooner or later anyhow, just not for this reason. I understand the importance of the heads on the 5.0 and if I am going to replace them I would really only like to do it once and get the cam at the same time. What would you guys recomend for this combo to go with a fairly stock 5.0(replaced intake so far)? The car is on the street 10X more then it is on the strip and because my mother was the original owner I do not plan on selling it.
  5. #15
    No need to get frustrated or discouraged from doing things yourself, you just have to learn that PB Buster is yo friend.
  6. #16
    gilbert
    honestly people there was no heating, pb blasting or back out bit that would have worked on that rusty nub.
    So any help with heads/cam choice?
  7. #17
    Mar 2008
    Phoenix , AZ
    I would go with an E303 cam would be your best bet.
    I still run the E7 heads with a little port work done and E303 cam, 373 gears and stock bottom end with ac, smog pump, power steering, and pulled 268 hp to the wheels
    93 FOX
  8. #18
    Senior Member 93mustank's Avatar
    Phoenix.AZ
    Set of canfield 195's ,custom billet cam and a victor efi
  9. #19
    Mar 2008
    Phoenix , AZ
    Quote Originally Posted by 93mustank View Post
    Thats some serious money for that set up.
    93 FOX
  10. #20
    gilbert
    this site is great......
