Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: brake swap for drag lites
    Member cline's Avatar
    Dec 2008
    virgina
    anybody do a swap on the front for 15" draglites?? what parts do i need for this? and can i just do a 2003 gt swap? getting ready to order the wheels. thanks .
    I run stock cobra front brakes with a 1" baer slip on spacer with Centerline Convo Pro wheels. The centerlines are not as thick of a rim in the area where the studs pass thru so everything is legal.
    Senior Member 93mustank's Avatar
    Phoenix.AZ
    1 inch spacer and a grinder............
    Quote Originally Posted by 93mustank View Post
    On a weld wheel the studs will not protrude into the lugs far enough to be NHRA legal with a 1" spacer.
    Legal
    Not Legal
    Member soap's Avatar
    MI
    Depends on what length front studs are used. I ran 3.5" ARP's and they were legal, the studs made it right to the end of the lugnut with a Prostar and 1" spacer.
    --Joe
    Fo Mo Co Mo Fo
    Quote Originally Posted by soap View Post
    --Joe
    Not legal. The first 1/2" of the stud is not threaded. It may have looked legal, but a 1" spacer with a pro star does not engage the threaded portion of the lug as depicted in the diagram above.
    Phoenix.AZ
    Legal
    Not Legal
    It gets past tech...so i would have to say legal.
    Dec 2008
    virgina
    well thats cheaper !!! dang skippy ! im doodin it !! thanks. pics coming soon.
    Dec 2008
    virgina
    aah? good point. plus i would feel safer with knowing that the wheel is on tight.
    MI
    Quote Originally Posted by cline View Post
    You still have to run a spacer with GT brakes. GT PBR calipers are nearly the same size as Cobra PBR's.
    --Joe
    Fo Mo Co Mo Fo
