Results 1 to 3 of 3
Thread: Need help with axle replacement
    Hey guys i need some help replacing my driver side rear axle. It snapped. When it snapped it pulled of the rotor so i already got the brakes off. So i know i need to
    Pull the diff cover
    Take out the 8mm bolt
    Take off the c-clip
    Slide out the axle
    But i need a new seal and bearing, what my question is; is that is there just a bearing and seal, or is there a cuppling (spelling?) as well that goes in after? idk because when the axle came off all that was left in the tube was a bearing and seal but i thought there was a cuppling that went in after you put those in. any help would be appreciated Thanks, and if anyone is willing to help ill pay for pizza and beer. Im looking at doing it this weekend if then next weekend for sure.
    I believe the bearing an seal just press into the axle end. It has been a long time since I did one.
    Ok thanks, hopefully it will be up and running soon, so i can come put some numbers down on the track w u guys, just got a bunch of stuff done to the engine so lookin forward to that.
