Results 1 to 10 of 19
Thread: Mustang Cobra--How to covert and ABS Sensor into a Speedometer Sensor
    This is a method to make an ABS sensor to works as a speedometer sensor. This is helpful for those converting to an auto transmission. The price to make a TH-400 work in a conventional manner was several hundred dollars. That drove me to look for a more affordable solution.
    Thanks to 03steve & street lethal for providing info to make this tutorial possible.
    This is how I tied into the Right Front ABS sensor.
    Warning
    This is for a car that does not have functional ABS.
    YE/RD is (+) Positive
    YE/BK is (-) is Negative
    • Go to the right fender remove the tire and liner then locate the ABS connection.
    • I cut the ABS connector out and taped off the Yellow wires going to the PCM.
    This connector replaces the speedo connector on the tranny harness. Name:  abs2.jpg
    After you cut the connector out you will have still have a Black and Brown wires going to the ABS Tone Ring. (You need to extend these ABS wires out to the tranny harness)
    The Black is +
    The Brown is -
    Purchased some new Red and Black wire.
    • Connect the new Red wire to the (+) Black wire going to the ABS Tone Ring
    • Connect the new Black wire to the (-) Brown wire going to the ABS tone Ring
    • I routed the wire thru the antenna grommet then behind the glove box and radio then down under the shifter bezel to tranny tunnel.
    • Now take the ABS connector you cut out and attach it to the new wiring in the tunnel.
    • Attach the new red wire to the (+) black wire on the connector.
    • Attach the new black wire to the (-) brown wire on the connector.
    Now it is time to tie into the speedo wiring.
    • Locate the (OSS) Output Shaft Sensor connector (Speedo) on the tranny harness. I cut the T-56 OSS connector off as the ABS connector above replaces it.
    The OSS wiring is
    DG/WH (+) positive
    GY/RD (-) negative
    • Connect the (OSS) DG/WH + to the (ABS) Connector YE/RD +
    • Connect the (OSS) GY/RD- to the (ABS) Connector YE/BK -
    Now you are done with the wiring and have successfully created an removable connection.
    Now the tune must be adjusted.
    The PCM needs to know how many turns of the OSS are required to make one revolution of the tire.
    The Front Tone Ring has 50 teeth.
    So you need to set the following parameters in the tune
    Number of holes for OSS sensor 10
    Axle Ratio 5.00
    Tire Revs Per Mile - (Set based on front tire data)
    The PCM will now calculated one tire revolution based on 50 pulses which is how many teeth are on the tone ring.
    GPS tested and accurate within 1MPH.
    May 2009
    milwaukee
    you cant just tap into the wires and still leave them connected to keep the abs functional?
    TT 99 cobra
    Quote Originally Posted by no_slow_svt View Post
    I have no data on that, but I think it could possible work.
    You can also have a GM electric setup installed in the TH-400 as long as you have and evenly spaced teeth on the reluctor wheel. I believe the wheel has 40 teeth and some machine it down to 5 evenly spaced teeth.
    May 2009
    milwaukee
    yeah i tryed to tap into one of the rear sensors like this.
    i dont have the car on the ground yet, (wating on my driveshaftstill)
    once get it on the ground ill be able to tell beter, then ill play with the wires to see whats going on.
    TT 99 cobra
    May 2009
    milwaukee
    ^ that sounds like to much messing around for me.:)
    TT 99 cobra
    May 2009
    milwaukee
    can you turn the ABS light off in the tune if you want to, do ya know?
    I tryed to keep everything hooked up and just splice into the harness, and my ABS light is on now. so im guessing it didnt work. but i have yet to drive it on the street.
    ill keep ya posted if it does work though.
    J
    TT 99 cobra
    J
    No the light will stay on. There is no way to shut it off in the tune.
    If the ABS light is on it is not working. Are you trying to make this work with the ABS?
    May 2009
    milwaukee
    burn, i switched the wires around and still nothing.
    what is the reason for reusing the connector?just to make disconnecting it simple(if you need to)
    basicly i took the two wires coming off the speed sensor on the trans and ran new wires right back to the black and brown wires coming off the abs sensor.
    am i missing something?
    its simple stuff i thought,I havent adjusted anything in the tune yet, but i wanted it to at least register something before i adjust the tune.
    TT 99 cobra
    I used the connector to make it removable if need be so it is not necessary. I assume the t45 uses an OSS like a T-56, but I am not sure.
    Are you driving the car to verify it is not working?
    May 2009
    milwaukee
    yeah im driving it. ive switched the wires back to how they were in the first place. and still nothing, checked all the fuses too and those are good.
    im stumped, and i hate these kinda problems. electrical sucks!! lol
    TT 99 cobra
