Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Lean Problem
    Lean Problem
    So my car Wide band goes very lean!! Under 2k rpms it will sometimes go all over the place from lean to rich which is normal but once I pass 2k rpms no matter what I do it goes lean enough to were the wideband cant read which is 17:1. I cant go full throttle and about 15 mph in forth gear and go wot and under 2k rpm its lower than 10:1 but once it goes about 2k or over it goes over 17:1 were the wideband cant read no more. Were do I start????
    04' F150 Supercrew
    check fuel pressure, fuel filter, and check the fuel pressure regulator.
    DannyStyle22
    Guest
    Quote Originally Posted by fazm View Post
    I agree.
    How Do you check the the fuel pressure regulater???
    04' F150 Supercrew
    Quote Originally Posted by ThePunisher95 View Post
    Do you have a blower on the car?
    Yes. A vortech
    04' F150 Supercrew
    Fuel pressure gauge? Are you running an FMU or just large injectors?
    Not yet. Gonna get the Tweecer to tune it. And I have a AEM Wideband. Im working on the fuel pressure gauge...
    04' F150 Supercrew
    This happened to me. Check your fuel pump, thats what was wrong with mine.
    49 lbs of fuel pressure and a new fuel filter. Still having the same problem
    04' F150 Supercrew
