Dash Light Replacement - LED Dash Lights
Finally, You Can Read Your Classic Ford's Gauges at NightAs we age, things get harder for all of us. For some it's hearing, others it's their knees, but for many it's their vision. As your vision fades, it takes longer to focus on items. A big issue for those with vision problems is night driving. Between the darkness, oncoming headlights, and dim gauge illumination, it can be a real struggle for some to safely drive at night. The dimly lit gauges of a classic Ford's stock instrumentation just aren't confidence inspiring when you get behind the wheel at the end of a cruise night to drive home. It's even worse when you hop from a modern car with backlit gauges into your classic. Then your original gauges look even dimmer.
Photo Gallery: Dash Light Replacement - Modified Mustangs & Fords Magazine
Full Story..
