Ok so I was getting a squeaky brake noise from the right front so I decided to change the pads and rotors on my Cobra. I ordered the factory replacement Brembo rotors (the italian ones, not the cheapo's), and the good replacement pads. After taking a short test drive and lightly braking, I get sort of a clunking sound in rhythm with the turning of the right front wheel. After another inspection the pads look fine and the rotor looks fine and true. When driving and not applying the brakes, I can hear the pads intermittently touching the rotors- again in rhythm with the front wheel rotation. The pedal doesn't pulsate. I immediatley parked the car as I don't want to ruin the new pads and rotors, but I thought I'd see what you guys think the problem may be. Any ideas?
I guess a trip to PSR will be forthcoming for them to check it out.
