Results 1 to 10 of 15
Thread: Need Opinions on a Brake noise
    Senior Member BLK03SVT's Avatar
    Scottsdale
    Question Need Opinions on a Brake noise
    Ok so I was getting a squeaky brake noise from the right front so I decided to change the pads and rotors on my Cobra. I ordered the factory replacement Brembo rotors (the italian ones, not the cheapo's), and the good replacement pads. After taking a short test drive and lightly braking, I get sort of a clunking sound in rhythm with the turning of the right front wheel. After another inspection the pads look fine and the rotor looks fine and true. When driving and not applying the brakes, I can hear the pads intermittently touching the rotors- again in rhythm with the front wheel rotation. The pedal doesn't pulsate. I immediatley parked the car as I don't want to ruin the new pads and rotors, but I thought I'd see what you guys think the problem may be. Any ideas?
    I guess a trip to PSR will be forthcoming for them to check it out.
    2011 Shelby GT 500
    Black/Black/Satin Black Stripes, Electronics Pkg, FRPP/BMR Suspension/Borla-Ford Racing Exhaust
    488rwhp/463rwtq bone stock
    Great Past Rides:
    2003 Mustang Cobra SVT Convertible- 302 Stroker & more- PSR Tuned, 2003 Mustang GT- Silver Coupe w/boltons
    1996 Mustang GT/SC- Paxton SC & Tons of Mods- SuperFord Mag Car, 1995 Mustang- Red w/boltons. 1968 Galaxie 500
    Hard to tell without hearing it. Mine make some noises at times. Along with the coilovers. LOL
    Could be normal or possibly a sloppy wheel bearing.
    You sure you installed the anti-rattle clips correctly?
    Scottsdale
    The anti rattle clips came on the pads. Only question I have is these rotate a bit- I wonder if they're in the wrong spot.
    It all seemed pretty self explanitory and easy....not sure why there's a problem. I never did think of the wheel bearings....
    2011 Shelby GT 500
    Great Past Rides:
    Its an exhaust leak....
    But seriously, I would have no idea
    They rotate around a bit? The set my buddy and I just did within the last month didn't move a bit. They were a nice snug fit. Odd.
    Senior Member Bandit's Avatar
    Apache Junction AZ.
    Go back and check your work...
    Sep 2008
    x2 , and use the brake lubricant on the moving/sliding parts of the caliper / backside of brake pads etc..
    Scottsdale
    Ok, I've checked my work twice. I went and picked up some caliper lube and lubed the caliper pin. The pads fit snug, and the clips fit snug as well. When I place the caliper back on the rotor the wheel spins freely and the pads don't contact the rotor- all is good. Once I start the car and apply pressure to the brake pedal, the caliper doesn't relax all the way, and it drags on the rotor. What would cause the caliper not to completely release it's grip? The car drives great, doesn't pull etc. Ugh it's frustrating because the noise is annoying!
    2011 Shelby GT 500
    Great Past Rides:
    Sell the car, lol. I would give PSR a call and see what they say. Or even bring it by
