Results 1 to 10 of 14
Thread: Mustang Motor swap
    Dec 2007
    Las Cruces, NM
    Mustang Motor swap
    Im looking to change the motor out in my 96 GT and was looking for input on what i should do. Should i look for a PI motor or should i build a 5.0 stroker motor. And if i was to drop in a 5.0 how hard is the conversion and what all would i need to make sure that it worked like it was supposed to. Any info would be Helpful!!!!
    You could also go 4V
    Senior Member Ruckus46gt's Avatar
    Luke AFB
    you planning on staying n/a or not? If you dont plan on going turbo or blown and are planning on staying n/a or nitrous then run your stock motor, swap out to some ported pi heads, and do a pi intake or even a p51 intake, and some cams. You will make more then a typical pi motor would with the same mods because of the bump in compression
    Dec 2007
    Las Cruces, NM
    Iv thought about doing a 4v swap but i havent been able to find one for it
    Dec 2007
    Las Cruces, NM
    i would like to run a supercharger some day but for the immediate future it would be na
    Senior Member AZSaleen04's Avatar
    Chandler, AZ
    I just did a 4V conversion from a 2V and you will need a lot of parts to complete is such as a full body harness, engine harness, computer, Heat exchanger and more. The 4V are expensive to buy as well however the power is completly different.
    You could rebuild your motor or if interested I do have the full motor, trans, harness and computer with tune for sale on here as well.
    2004 Saleen Convertible #298 SC/281-SOLD
    1970 Chevelle LS3 Build/T56
    Luke AFB
    could build a fast car and do something like this
    http://ls1tech.com/forums/showthread...=mustang+96-98
    or go all out like this
    http://ls1tech.com/forums/showthread.php?t=637163
    Dec 2007
    Las Cruces, NM
    where would you suggest that i look for a rebuild kit cuz i want to motor to make more power than the current one
    Luke AFB
    Quote Originally Posted by 96VERT View Post
    go right through fox lake and order heads, cams, and intake from them. If you want to swap out rods pistons and that just go through mmr but at that point might as well just buy a new motor from them
    Dec 2007
    Las Cruces, NM
    what type of intake manifold and heads would work best if i want to supercharge it in the future but cant do it right now
