Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
Thread: Converting Saleen engine to 04 Cobra setup!
    Senior Member AZSaleen04's Avatar
    Chandler, AZ
    Yes something to consider for sure!
    2004 Saleen Convertible #298 SC/281-SOLD
    1970 Chevelle LS3 Build/T56
  2. #12
    Chandler, AZ
    Money is tight right now but what would I be able to get for my Saleen motor with the supercharger? Mileage 19,500.
    I also need to consider labor for swapping out the engines. Any thoughts what that might be?
    I would need to find out what parts are needed to make the Cobra motor fit the Saleen. I talked to someone and they told me wires need to be lengthened, not sure what else is involved.
  3. #13
    Don't lengthen wires. It can be done but its not the same. Do it right the first time. You will need a 4 valve computer and wiring harness.
    You would probably get more money if you sold the blower and motor separately. A low mile PI 4.6 longblock could probably fetch about 2k without too much effort. The blower $1500-$2000.
  4. #14
    If money is tight, then stop right where you are. Youre gonna need wiggle room once you start changing motors and adding more boost.
    Id PM the seller of the 03 engine. He may have a lot of info that will help you
    74 Bronco 302/C4
  5. #15
    Senior Member chewbaccajones's Avatar
    Atlanta
    Senior Member About2Bite's Avatar
    Feb 2008
    Chandler AZ
    Quote Originally Posted by chewbaccajones View Post
    Nice find
    Black 04 Cobra
    KB 2.2 @ 19#'s, 3.25(15#) upper, 4# lower, CAI, Kooks LT's, Catted H,
    SLP LM1 CB, 60# inj, BF idlers, BF TB, Zoom ZVT Stage 3, 26 Spline, MGW,
    2400 MAF, Ron Davis Racing HE, SCT tune, AFS 10.5, 315/35/17
    Quote Originally Posted by wickedcobra View Post
    I have it worked out with my wife too, I get car parts, she gets brooms, vacuum, irons etc....LOL
  7. #17
    Chandler, AZ
    Thanks everyone for the advice. I've decided to go for the 32V set up in my Saleen, however I've lost out on the one that was listed here for $5K as well as the one in CA.
    If I could find a good deal on the motor and blower I will go through with it. Please let me know if you know of one for sale locally here in AZ with low miles.
    Thanks again!
  8. #18
    Atlanta
    just keep checking the various stang sites and craigslist in the bigger nearby cities like SD, LA...
  9. #19
    Senior Member Venomous Bite's Avatar
    to cool to put it down
    I did this swap on my Saleen about a year ago.
  10. #20
    Chandler, AZ
    Thanks and I will keep and eye out. There were three that I knew of and they are all sold.
