Results 1 to 10 of 13
Thread: Cyclone fuel savers
    Question Cyclone fuel savers
    OK so i have heard that they are Fraud and after thinking about it for 75 bucks they would be. But curious i was reading some other forums and they were all talking about how ba dit was but they were talking about it being on fuel injection cars. now if its in the air intake on the car then by the time the air passes the fins It may spin but by the time the ari gets to the motor it wuld be spining anymore. plus the fins trying to get the air to change direction would constrict airflow. but one guy finally got smart and starting about the old carb motors. if you put it inside the filter right about the carb intake. would the air comin through the filter automatically start spinning and eventually spin through the Cyclone and straight down into the carb. just seeing what other peoples opinions are on this topic
    Senior Member santa_rosa_lt1's Avatar
    santa rosa,ca
    Id say don't waste your time.I haven't seen any proof that they would give you better fuel economy.
    IMHO
    2003 svt Lightning
    chickenears cai
    bassani catback
    bassani catted mid
    LFP stage one W/ 4lb lower
    Fluidyne HE
    a little faster then stock.
    Not only that. How long is it going to take to save you $75 in gas? Would changing your driving habits just a little bit save you more?
    waste of cash. not even worth your time. i think jeff has the best point to be made. you could probably save more by not mashing the gas as hard. but, thats easier said than done.
    i have actually eased out on the gas but still well i was just curious because the deign it simple and you cn make it yourself
    Senior Member 06GT's Avatar
    Jun 2007
    Chandler, AZ
    I hear if you put 5 Tornado Air fans in sequence in the intake, you can get 5lbs of boost on an N/A car :)
    seriously?!?!?!
    Member Double0Fox's Avatar
    Covington Washington
    I can't remember but someone did a couple Dyno runs with one, and they actually saw a 1 ot 2 hp decrease. If I find where it was I will post it up. If they really worked, you would see OEM ones in cars.
    2000 GT Vert / On jack stands.
    santa rosa,ca
    i seen it on myth busters too!
    wasn't it more like 5.5lbs boost?
    2003 svt Lightning
    chickenears cai
    bassani catback
    bassani catted mid
    Fluidyne HE
    true i can see the carb ones working but the one in a fuel injector wouldnt make sens eht eifve i can see because it would finally get the air moving
