Results 1 to 9 of 9
Thread: help on oil pressure sender
    Senior Member YellowGT5.0's Avatar
    Gilbert Arizona
    Today i attempted to put my autometer oil pressure sender on and the unit will not fit. It's way to big in diameter and hits my block. Am i doing something wrong or what?
    Senior Member Stern90LX's Avatar
    Prescott Valley, AZ
    Sounds like you need a pipe extension to clear the block like the 84-93's had.
    Here's a pic with it installed on my 5.0 : http://i57.photobucket.com/albums/g2.../P9010028e.jpg
    Edit: Not the circled item in that photo btw. That's the ACT Sender :).
    The Pony Car Wars are over... The Mustang Won
    Or build a lil setup with the correct fittings (what i did on my 95)
    Gilbert Arizona
    Quote Originally Posted by 4Jenna View Post
    Ill try that next time a attempt it, Thanks!
    oil? use the stock extender.... If it is the wrong thread retap it with a pipe tap. CLEAN there you go. on the pic it is the long silver thing on the front right side of the block.
    94-95s dont have that Seth
    oh sorry. Thought they did. Go to a Junk yard and pull one off a fox body. I might have one.
    Gilbert Arizona
    Ill just go by work and find some brass fittings and make something up and see how it goes
    Member stangboy86's Avatar
    NY, soon to be AZ
    Quote Originally Posted by YellowGT5.0 View Post
    if you need one let me know i have several and ill give you one, you just pay the shipping, cant be more than a few bucks
