For sale
1994 mustang Black in color.
Engine stock in appearance only
352 CI motor
A4 block 4 bolt main balanced and blue printed by Kenny brown
Carillo Rods
JE forged pistons
Head studs
SVO aluminum heads
Roller rockers
Cobra intake
24# injectors
under drive pulleys
65mm t body
custom cam
clotes double roller
billet balancer
Drive train
T56 viper spec
Weldon pump ran to the brake ducts
Billet flywheel
Centerforce clutch
Custom drive shaft keny brown
Custom trans mounts Kenny brown
Triax shifter / pro 50 handle
Rear end
Maximum motor sports pandhard bar
Built 31 spline rear end
Detroit diff
456 rear gearing
Cobra rear brakes
Kenny brown lower control arms
Kenny brown upper control arms
Weldon pump rear diff cooler ran to the brake ducts
Koni 5 way adjustable shocks
Front end
Maximum tube k member
Maximum control arms
Maximum caster camber plates
Koni 5 way adjustable struts
Maximum motor sports coil overs 600 springs
Maximum strut tower brace
Cobra rack and pinion
Fuel system
255 intank fuel pumps
fuel safe
brakes
Brembo 6 piston front calipers
Brembo 2 piece rotors
Brembo rear brakes
Brembo cobra rear calipers
Cobra master cylinder
Cobra brake booster
Safety
10# halon system
Body
Carbon fiber cobra R hood
Kenny brown carbon fiber brake duct vents
Saleen s281 wing
Cobra front nose
2004 chrome svt wheels 17x9-17x10.5
nitto 555 275x35x17
Nitto 555R 315x30x17
All original cobra head lights
On off switch in the rear
Int.
2000 mustang saleen dash
95 cobra instrument cluster
black int.
recaro front seats
battery relocation kit
As you can se I have gathered quite a few nice parts here and put them together to make a rather nice car. I will sell this car for the right price however I al also always looking for / up for trades up or down. Please keep in mind I have spent a lot of money in this car and will not give it away. Cash wise I’m looking for around 23-25k at least shoot me a pm if you have a trade with all of the details and pictures and ill let you know. I use to use this car for road racing but I stopped driving it about 6-8 years ago and left it at my moms house in the garage and to tell the truth I forgot it was there until I went back home a few moths ago for the first time. So this car has not been raced since 1999 and has not been driven since 2002 the car would get started one time a month and ran for 30 min every month since it has been parked. The paint is black and I would repaint it if I were to keep it (this is still an option) the car is still sitting in the garage. I did jack the car up and install the new cobra wheels and tires that are new. The dash was changed out in 2000 in favor of a saleen unit I had because I wanted to ditch all of the under dash stuff ( I still have the stuff it just not in the car) everything works fine on this car. Thanks for looking
