Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: LDC Cooling Mod Help
    Dec 2007
    new jersey
    Whats up everybody.
    Quick question does anyone have this LDC cooling set up in their 03 or 04 cobras? Do you reccomend this on cobras that have the blue stripe around the drivers side head (I think this is the updated design correct me if I am wrong)? If you do reccomend this mod what style should I go with? Thanks.
    There has been a big heated debate over this mod. I personally have it as it can't hurt anything by creating more flow out of the head.
    I have the blue stripe and I used the LDC Cooling mod.
    You can get the LDC kit here
    http://dagostinoracing.com/index.php..._122_1420_1785
    i do know when i have to do a clutch i will be adding the ldc cooling mod to my car. its looks like one of the best ones out there.
    Senior Member About2Bite's Avatar
    Feb 2008
    Chandler AZ
    Have it on mine too, can't hurt anything, but some believe it doesn't help either. I say if you are pulling the trans out, What the hell, throw it in there while you're at it.
    Josh
    Black 04 Cobra
    KB 2.2 @ 19#'s, 3.25(15#) upper, 4# lower, CAI, Kooks LT's, Catted H,
    SLP LM1 CB, 60# inj, BF idlers, BF TB, Zoom ZVT Stage 3, 26 Spline, MGW,
    2400 MAF, Ron Davis Racing HE, SCT tune, AFS 10.5, 315/35/17
    Quote Originally Posted by wickedcobra View Post
    I have it worked out with my wife too, I get car parts, she gets brooms, vacuum, irons etc....LOL
    Senior Member chewbaccajones's Avatar
    Atlanta
    Damn, you gotta pull the tranny to do that?
    Yes you need to pull the tranny.
    Member mfj's Avatar
    Phoenix, AZ
    i am also wondering if i should have psr do this to my car, since their building my whole set up........ hmmmmm???????????
    Wisdom is simply the awareness of your own ignorance.
    HAVOC
    Quote Originally Posted by mfj View Post
    Can't hurt, it looks like a much better kit than the one from Apten. I know I'll be doing one on the Mach the first time I have to yank the tranny.
    Feb 2008
    Chandler AZ
    There is another one Amazon carried that I don't believe you need to drop the trans for. Even Flow head cooling mod?
    Josh
    Black 04 Cobra
    Senior Member Venomous Bite's Avatar
    to cool to put it down
    I have it in both my cars, obviously I like it. I don't see how it could not help. Stock there is no coolant flow what so ever to the back of the head, so obviously some coolant flow is better then no coolant flow.
