Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 25
Thread: LDC Cooling Mod Help
    Senior Member About2Bite's Avatar
    Feb 2008
    Chandler AZ
    I agree competely, the LDC is the best one available and requires the trans to be dropped the evenflow Head cooling mod can be done with the trans in place but requieres the removal of the blower although there are guys who have done it with the blower in place.
    If it were me i'd wait until the trans needs to be dropped and do the LDC mod then. It definately won't hurt anything.
    Josh
    Black 04 Cobra
    KB 2.2 @ 19#'s, 3.25(15#) upper, 4# lower, CAI, Kooks LT's, Catted H,
    SLP LM1 CB, 60# inj, BF idlers, BF TB, Zoom ZVT Stage 3, 26 Spline, MGW,
    2400 MAF, Ron Davis Racing HE, SCT tune, AFS 10.5, 315/35/17
    Quote Originally Posted by wickedcobra View Post
    I have it worked out with my wife too, I get car parts, she gets brooms, vacuum, irons etc....LOL
  2. #12
    Member mfj's Avatar
    Phoenix, AZ
    so if the hose were to mess up, or the clamps were to loosen, or a leak were to occur, it would require the removal of the transmission to fix it???? yikes!!!!! no thanks, IMO....
    Wisdom is simply the awareness of your own ignorance.
    HAVOC
  3. #13
    Quote Originally Posted by mfj View Post
    God just get the mod. You worry too much
    If your heater core hose comes loose you are in the same boat of hard to get to.
    Member mfj's Avatar
    Phoenix, AZ
    i'll ask dan.... my funds are running down, lol
    HAVOC
  5. #15
    Feb 2008
    Chandler AZ
    It's better than the tick followed by spending a few grand for the updated heads imo
    Black 04 Cobra
  6. #16
    Member mfj's Avatar
    Phoenix, AZ
    updated heads don't need the ldc cooling mod??
    HAVOC
  7. #17
    Feb 2008
    Chandler AZ
    They aren't prone to develope the tick like the old head design is, they can all benefit from the Head cooling mod. These motors produce so much heat any mod that helps lower those temps and your IAT's is a good mod to do, LT's, Heat exchanger, port etc.
    Josh
    Black 04 Cobra
  8. #18
    Lets look at it this way. The right head flows coolant out the back for the heater core. The Left head doesn't.
    The LDC mod allows both heads to flow out the back.
    You can make a determination on which will provide the best coolant flow.
    so what you are saying is it flows out the back of the head? LOL.
    I will be doing the mod before summer.
  10. #20
    Yes it's rocket science.
