Looks great I hope to see it at the show!
how do you adjust fuel pressure?
.98 my bad, the 94-95s cpu like to control the TPS voltage even after you set it...some say it is a waste but if you put a new TB etc on it def needs to be checked. If this is off it can help idle issues ALOT.
I went to a FOX TB and TPS on my car so I dont know if this will help but...
-Probe the Green Wire (i think the SN95 TPS has diff color wires)
-Ground
-Loosen screws on TPS and adjust TPS until you read .98 on the voltmeter.
*Sometimes you have to enlargen the screw holes on the TPS to acvhieve .98 as they wont allow enough adjustment.
-Also getting the set screw on the TB throttle blade just right helps with idle.
Do a search on the web, there are detailed instructions on doing this that likely are better than my attempt to explain..haha.
Does the car surge, or die at stoplights?
where can i get a tune? and how much.. This problem has gotten worse, its very frustrating, i want to drive my car!!!
shoot the guys at PSR a call, 602-269-8955. i am sure they can get you straightened away...
well right now its surging and dying when i come to a stop only sometimes. i checked the tps and the voltage reads a .98 so thats a good start we just replaced the iacv and that just made things worse.
Time for s tune...call PSR!
