Results 1 to 3 of 3
Thread: Shift Light Help
    Senior Member TruBluScreamer's Avatar
    Dec 2006
    Glendale, AZ
    Shift Light Help
    So im gonna be installing a digital tach with a shift light and I wanted to see who has done these and the easiest way to do it. The instructions say to hook it up to a 12v switched source, ground it , and hook it up to the tach terminal on the ECU this is the part im confused about if anyone could offer up some tips or ideas that would help me out that would be greatly appreciated.
    Here is the link to the product. http://www.glowshiftdirect.com/index...ROD&ProdID=298
    2003 True Blue GT
    PA Racing K Member
    MM Full Length Sub Frame Connectors
    H&R Drag Springs
    Mac Long Tube Headers & Mid Pipe (CatLess)
    Bassani Cat Backs
    Pro 5.0 Short Shifter
    03 Cobra Wheels w/ ET Street DR
    SCT XCal 2
    This is how the Raptor (The one I recommend) is done.
    Not sure if it applies to your unit.
    http://www.raptorperformance.com/For...1999to2004.htm
    Dec 2006
    Glendale, AZ
    yeah i read that one and it looks like it might work but it says something about selecting the 1 setting since youre only getting one coil but mine only has a 4, 6, and 8 cylinder setting
    2003 True Blue GT
    PA Racing K Member
    H&R Drag Springs
    Bassani Cat Backs
    SCT XCal 2
