Thread: long tube headers
    Exclamation long tube headers
    ok you guys sead to do exhaust and some suspension how bad is it to put long tube headers in my 99.I also ordered steeda sport springs .will I have ground clerance problems? looking for more power and handling .so please lets heare some in put .Also thinking 17-10.5 cobra r in the rear and 17-9 in the front
    Jan 2009
    i install them all the time
    Junior Member Black96SVT's Avatar
    NJ
    you will have no probs with the rims, not sure if an IRS bolt would have to be ground a little but I can't recall
    as for the LTs, its easiest to drop the K member, and do the headers that way, then once they headers are done and you put the k member back on you can put the springs back on before you bolt up the finishing touches
    Kooks LT Pro Chamber Cherry Bomb Extreme Tri Ax w/ Roush Handle VIS Racing Tokico D Spec Roush Springs Front GT Springs Rear Steeda SF Connectors HPM Mega Bite Jr. LCAs UPR UCAs Fluidyne Rad 180 Deg Stat UPR CAI CenterForce Dual Friction Fidanza Fly AEM Wideband AutoMeter FP & N2OP & Water Temp NX Wet Kit & Filter & Heater Cold Fusion Purge NGK TR6 FRPP 9mm
    Tuner: XCal2 SF and D'Agostino and Erick Brooks
    Drag: ProStars 15x3.5 & 15x10, MTs
    Senior Member Phx99Cobra's Avatar
    May 2007
    I have heard that on are cars and the mach ones the lt's didnt do that much for some. If your going to go lt make sure you tune it to let to get the most for your buck. You will have a little groud clearance issues it just depends how low your car already sits
    jlt cai, o/r bassani x-pipe,magna pack cat back, tri-ax, sct tune by keith @ az dyno chip, solid axle w/ 4.10 gears
    Best time...12.797 @ 108.5 mph w/ 1.76 60ft
    New Best Time....12.3911 @ 106.3 w/ 1.589 60ft
    SOLD
    New Toy - 2003 GT stroker, procharger and to much other s**t to list ***SOLD***
    The big gain is you pull a bunch of heat away from the heads. Also the better flow will lower your boost if you have forced induction.
