Help With 4v Swap
hey guys i was thinking of doing a 4v swap on a 96 gt... need to know what all is needed to do the swap and if any one had any pointers...
from what I have read its not too bad of a swap (im assuming you are putting a 96-98 cobra motor in?) there are a bunch of links on Modular Fords about the swap, anything from 96-98 cobra motors to 99-01 cobra motors 03-04 mach motors and even some aviator 4v swaps...I would say it would be cheaper to build the 2v but then again you dont have the PI heads so you might as well go 4v.
try here: http://www.modularfords.com/forums/s...=4v+swap+96+gt
2nd post down
