Thread: HPS issues with IE6
    So Cal
    HPS issues with IE6
    Run into this problem at ModFords too. Not sure why, but when I do log on, it tells me I am not. Posting is a bit tricky too, since it works with Quick Reply sometimes and sometimes it wont.
    Am I the only sucker with IE6 at work?
    Click the remember me block when you log in.
    Use Post Reply instead of quick reply.
    Not sure what the issue is, but it is software related.
    So Cal
    Remember me isnt working either...
    Odd...it works just fine with IE7. IE6 makes me push F5 all the time!
    Quote Originally Posted by P Machy View Post
    Are you logging in from the Home Page or the Forums?
    So Cal
    Forget the Home Page. It gets stuck and I see it trying to refresh or something.
    Believe alot of folks are going with the IE7 anyways....i should convert the work PC over.
    IE 7 is much nicer. The tabs are great.
