Results 1 to 10 of 20
Thread: MAS help
    Quote Originally Posted by JE's00GT View Post
    Can I use my tuner adjust for this? It ask which MAS I have and actually has the one I bought as one of the recommended.
    You need to be able to read the air fuel to tune a new MAF. You may be able to adjust some fuel with the the tuner, but a custom tune is the best.
    What MAF and Sensor brand did you buy?
    Missouri
    It is a Ford Racing brand. I guess I need to find a place to get it calibrated? I am new at all this so I am sorry if I ask a lot of questions.
    Do you have a link to what you purchased. I don't see a ford racing MAF for a 2000 GT on the Ford Racing Site.
    If the sensor has different electronics than stock your cars tune needs to be adjusted for the new sensor.
    Missouri
    It is for a 2001-2004 ford lightning. I got it cheap brand new and figured I could make it work. How and where might I get adjustments done? I do appreciate your help.
    Ok you will need to have the car taken to a dyno and tuned.
    On a fairly stock 00 GT this is a waste of money. I would just stick with the Cold air intake and stock MAF meter.
    The only reason to go to a larger MAF meter is due to your current meter pegging. The meters reads 0-5 volts. When you reach 5 volts you are considered pegged. That means if you car has the ability to flow more air the computer will not be able to read it as the meter is at its max reading.
    Unless you are moving a ton of air you better off spending the money on other mods.
    Missouri
    Thanks Jeff. Have any mods in mind that would make a difference without a huge amount of money? I do plan in the future for a supercharger and all that but right now im taking it slow. I have flowmaster exhaust, Cold air, Pro 5.0 shifter, tuner and im sure more i can't think of right now. But really thanks for your help. I will put that MAS away for maybe something in the future.
    Do you have gears yet?
