I just did the LDC cooling mod when I did the clutch(Thanks for the help Ron!). I tried to to remove the plug on the cross over but it wont budge. I used a 1/4in ratched to try and remove it but its starting to strip. Any ideas on how to get it out.
Heat it with a torch!
If you don't have one go get a small soldering tank.
I went a bought a torch and got it loose with out any problem. I filled it up through the cross over and filled the resovore and drove it let it warm up and it is fine. Thanks for the tips guys!
Ya my drive way is pretty slanted and that helped a bit.
