Results 1 to 10 of 14
Thread: Fuel rail sensor?
    arizona
    Fuel rail sensor?
    Whats the method on determining if a frps is faulty?
    Car will run like crap. Trouble idling and getting into the throttle?
    Are you having a problem?
    arizona
    Yeah,i was driving around today and went wot my Autometer fuel gauge hit zero and then popped back up to normal. I have 2 frps sittin around but I'm not sure if thats the problem.
    Do you have the Kenne Bell disk in the rail?
    arizona
    Yes sir. Do you think it sounds like fuel pumps?
    Hum. Not sure. I remember having this conversation with Joe before. It happened to him one time then never again.
    Do you have a boost a pump?
    Jan 2009
    hahaha that sheit dont work. I never had an issue with my car and I installed one the next day the car had an issue with the sensor so I removed the disk and it ran fine so I threw the disk away ...
    Quote Originally Posted by Dan View Post
    Yep. 8800 miles and original FRPS. Don't work. Blah.
    Senior Member Viper_ed's Avatar
    Monessen, PA
    When mine went, the car just died and would not restart. It would sound like a car that breaks a timing belt when you tried to start it. If this ever happens, you can unplug the wire from the FRPS and the car will start and you will be able to drive it home to fix it.
