Results 1 to 10 of 28
Thread: I need help people!!!!!
    Sierra Vista, AZ
    Ok, I have an 06 GT with a Saleen S/C pushing 10lbs, GT Dual Fuel Pumps, 90MM MAF, Saleen Extreme Intake Tube, Full Borla Exhaust (LT Headers, Off Road X, Cat Back w/ S types), 39lb Inj, and a few other odds and ends. It's an automatic AND WILL BE STAYING THAT WAY!!!! I want more power. Lots more power. I'm pretty sure i want to stay away from nitrous. What direction should I go???? I know I need wheels/tires, a good suspension kit, gears, and brakes. Specifically, what should I look at for these things, and more importantly, what should I do to add power???
    WWW.MySpace.COM/DrumSTW3
    Well if you want more power you need more boost, but if your on the stock block you don't want to crank up the boost anymore due to the lack or forged internals.
    A turbo kit at 10PSI will generate much more power due to the elimination of turning the blower.
    As far as suspension what is your primary use for the car? Drag strip or more of a daily driver/ handling setup?
    I guess it comes down to how much money you want to spend.
    Sierra Vista, AZ
    Money isn't the issue, but right now it is a daily driver, so practicality is important. I want to stick with the S/C i have...
    Senior Member Phx99Cobra's Avatar
    May 2007
    I say some cams and ported heads, but I agree if your not going to boost the s/c more turbo is the most efficent
    jlt cai, o/r bassani x-pipe,magna pack cat back, tri-ax, sct tune by keith @ az dyno chip, solid axle w/ 4.10 gears
    Best time...12.797 @ 108.5 mph w/ 1.76 60ft
    New Best Time....12.3911 @ 106.3 w/ 1.589 60ft
    SOLD
    New Toy - 2003 GT stroker, procharger and to much other s**t to list ***SOLD***
    built motor, heads/cams and up the boost to the 20, and ull be happy for a while. after thts not enough anymore, ur gonna want a turbo, its just how it is lol.
    jeff acts like he doesnt want a turbo.... :)
    I agree build the motor and spin that blower!
