Idea mezier electic water pump
im getting ready to install te mezier electric water pump Ill tell you what gains i see
I heard bad things with those. One, being that the older ones leaked, but i guess they "fixed the problem".
this is a new one and yes they do leak if you dont use dialetric when installing it . Imagin that lube works wounders lol make one think what they use when having sex lol
Super Moderator
I'd shy away from it if it were my car. I dont think it can flow enough in the high RPM's where we need it most.
Super Moderator
Originally Posted by
Dan
the name said it all
did you install it?
I have a Evans Water Pump. I like it. I did that along with a LFP radiator and 180* thermostat (with holes drilled). All I can say is it takes a long time for the needle to the reach half way mark.
Luis
Running a Meziere with a 160 tstat and larger rad. I did not see any numbers on the dyno from lets say back to back runs. But I think that it is worth it for a car that sees drag race time for staying consistent.
Chad
Ill post numbers they garentee 10-11 hp
I have a meziere on my car. definately runs cooler in stop and go traffic. as for power, I didn't dyno it before and after, but should be worth a few ponies. the ones back in the day for pushrods were pretty bad on street cars, but the mod motor ones flow more than the stocker ever will especially at low rpms.
