Results 1 to 10 of 10
Thread: Help!!! Will 15X8 Welds with 4.5" backspacing fit???
    Senior Member TorchedMach1's Avatar
    Got some new Welds and ET Streets!!!
    I found a great deal on a set of 15X8 Weld Draglites with some ET Street Radials mounted. The Welds have 4.5" of backspacing. I was just wondering how well this setup will fit on the car. The ET Streets are like 26X10.
    Also I have a built rear with GT brakes so no worries there.
    Arizona's Fastest Mach 1
    11.14 @ 120 w/ 1.48 60'
    GO-FAST MODS
    Magnaflow O/R X-Pipe
    Magnaflow Catback
    Steeda CAI
    Torch Red JLt Intake Tube
    Steeda Tri-Ax
    Spec Stage 3 Clutch
    Built 31 Spline Rear w/ 4.10's
    Rear Upper and Lower Control Arms
    NX Wet Kit (100 Shot)
    SCT Chip
    Custom Tune by PSR
    yup, thats what i run on my car. and i have a built gt rear end too.
    Sweet thanks for the info. I'm actually getting ready to leave and go check them out now.
    GO-FAST MODS
    Magnaflow Catback
    Steeda CAI
    Steeda Tri-Ax
    Spec Stage 3 Clutch
    SCT Chip
    Custom Tune by PSR
    sweet. now that i think about it though, i actually run a 15x10, but same backspacing. so 2" narrower will not hurt anything....
    Well I went ahead and got the wheels and tires. It was an awesome deal. I paid $220 for the set of 15X8 Weld Draglites with centercaps, and M/T ET Streets. The rims are in great condition and there is still tons of tread left. I'll post up pics later. The only problem was he only had 7 lug nuts and washers. Where's the best place to pick up 3 more lugs and washers?
    Yeah I can still run a 275/50R15 ET Street on these 8" rims, which is like 11.5" wide. That should be more than plenty for me.
    GO-FAST MODS
    Magnaflow Catback
    Steeda CAI
    Steeda Tri-Ax
    Spec Stage 3 Clutch
    SCT Chip
    Custom Tune by PSR
    i think lopers would be the place for the lug nuts....
    Quote Originally Posted by TorchedMach1 View Post
    its just under an 11" tire. but you will probably only have a contact area of 9.8-10" because of the narrow rim.
    Posted some pics
    GO-FAST MODS
    Magnaflow Catback
    Steeda CAI
    Steeda Tri-Ax
    Spec Stage 3 Clutch
    SCT Chip
    Custom Tune by PSR
    So Cal
    For 220bucks it isnt bad deal, but the 4.5 backspacing is all wrong. You want 5.5 backspacing....you may need to grind on the banjo and caliper. My weld was rubbing on both sides on the Mach1.
    Also them tires are almost done. Once they become bald, look for signs of cords to start showing up. You can still make a pass or two if you dont have any tires and they still 60' ok with cords showing. .. but not recommended.
    So Cal
    btw: carefull on the return road. If the tires pick up enough rocks, due to the wrong offset, you will hear rocks hitting the roof and for sure u will have little chips on the outside of the fender.
