Results 1 to 3 of 3
Thread: new to Nitrous! need help
    so I got this kit for a 5.0 it is a bunch of different miscellaneous components. Zex 10lb bottle, edelbrock fuel and nitrous solenoids, and an edelbrock series 2 nozzle. I'm putting it on my bbf 429. I will be retaining all of the 5.0 factory fuel injection. I have coast high performance EFI Spider plenum and fuel rails. With a C&L mass air. The motor is a:
    1969 460 block
    Steel 429 crank
    440 dodge rods
    Custom 13:1 forged pistons
    Cam specs: dur@.50 I.272 E.282 Valve lift.665 Lobe sep.110 Solid Lifter
    Ported DOVE heads
    Stealth duel plane manifold
    What i need to know is if the nozzle that i have is going to work, and, the jets that i have right now are .026 and 120, what does that mean?
    Junior Member knuckles4696's Avatar
    May 2007
    gold canyon
    the nozzle will work in your app. only way it wouldnt would be if you had carburation in wich case you need a plate. It will go in your intake tube prefferably 3-6 inches from the throttle body. as far as the numbers, there jet sizes, if you call holley{nos} they can tell you what size shot they will give you.http://www.dynotunenitrous.com/store...ousjetcalc.asp
    this is a good place to find out what jets you need for your desired shot anyways goodluck hope i helped.
    "chitown brawler"
    sweet! thanks!
