Results 1 to 10 of 13
Thread: T56 Dowel Pin to Bell Housing
    So Cal
    burntire or anyone...I am missing a dowel pin on the T56 it self. Am I OK to just install it to the trans, or should I find one specifically for the T56?
    I got some dowel pins from the previous T5 to Mcleod BH, but the size is a little larger that requires some work to make it work.
    Dont want an aligment problem from the T56 to BH and to the pilot bearing.
    I would say if you can machine the T5 one down to the T56 specs you would be fine. Can you get this dowel from ford?
    So Cal
    Thanks. I hope I can get it from Ford tomorrow. Will know what the dealer says....lol, need a few things from the dealer actually.
    Well, I dont have a mic to get accurate measurements, so I am avoiding that obtion for now. Dont want a mis-alignment issue...this T56 is freaking heavy compared to a T5 or TR3650!!! Back Breaking heavy
    Quote Originally Posted by P Machy View Post
    I don't see any alignment issues. I think the dowels are more of an installation aid. It is not like they press fit into the bell housing.
    But if Ford has them do it right.
    So Cal
    That is what I thought too. Wasnt sure how they figured in the center run out for aligment, but it doesnt really seem all that adjustable.
    PM-ed Steve from Tousley...he has been good, but I know for sure he cant get Transmission bolts that go to the motor. Sadly some parts are not that easy to get.
    Just want to do it right
    Senior Member Indy's Avatar
    PHX AZ
    You can get that pin from the dealer, but it may have to be ordered.
    Senior Member Viper_ed's Avatar
    Monessen, PA
    The bolts will keep everything lined up!
    Jan 2009
    by one from ford
