Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Level 5 Problem Returns
    Ok I spent a good bit of time analyzing my findings after removing the new style halfshafts yesterday. I had 160 miles on the newly designed shafts and hubs. I can assure you these were pressed and installed correctly.
    I created a video of my findings.
    This is not intended to bash DSS. Hopefully this video can help find a solution to this problem.
    I pulled the video. I think the issue is known well enough.
    Jeff you should get a OSCAR for you movie making skills. i find this true documentary to be very very helpful
    Junior Member autoxstang's Avatar
    Mar 2007
    Savannah, GA
    Wow makes me want to check my axles out. Thanks the informative video Jeff.
    2004 Redfire Cobra, #583/3768, Born 11/26/03
    2.8 KB numbers coming soon....
    Florida
    Great job on that video. Very informative and well played. I learned something new from that too. Even being a GIRL lol lol
    And the Oscar goes too........BURNTIRE
    wow. very nice video. explains the situation very well.
    also makes one hell of a case for the solid axle.
    Senior Member u1arunit's Avatar
    Very well done Jeff!!
    Has anyone posted a link to your post or video on Mod Fords? If not we need to for sure!
    Mark
    Steel City Terminators
    '04 Black Cobra
    663RWHP / 665RWTQ
    Member speedracer's Avatar
    Oct 2006
    Somerset co. Pa.
    Quote Originally Posted by u1arunit View Post
    As of about an hour ago, no. Nice video, explains it all. l normally don't watch videos over 2 minutes cuz of dial up but I let the whole thing load.
    2003 SVT Cobra SUPERCHARGED!
    Just your average mostly stock Cobra (stock tune and pulley) SLP cat back and a K&N FIPK. 420rwhp, 400tq 12.28@117.98
    Mark I just wanted to see what everyone at HPS thinks about the video before I released it to a bigger audience. I will link it up later today being it is an Oscar performance. LOL
    Some up close pictures.
    Picture of the wear on the outer CV
    Groover in the spacers
    Note the metal shavings on the spacer
    So Cal
    Man...it would of just been way cheaper and less down time just to buy a few stockers. Least you would not have so much drama and down time while every one else was having fun at the strip. Still, not sure if the stock IRS can handle actual SLICKS vs DOT tires.
    Mechanical Failure isnt so bad after the 1st time....you get used to it .
