Results 1 to 10 of 16
Thread: Maximum vs UPr
    Flagstaff
    Maximum vs UPr
    I want to change out the stock K-member for either the maimum or the UPR. I have the Maximum rear grip pack (panhard bar, Torque arm.....). The MM is very expensive 1700 with instal (500). If I went with the UPR or comparible what would anyone recommend. My concern or assumption is that these suspension kits are engineered to match and balance (center of gravity) and if I choose a different set up would it really matter. The UPR as I understand it is ~700. (need to follow up with what that really includes). Suggestions...........................
    Senior Member Olivas's Avatar
    Denver, CO
    If your trying to decide between just those two, I would say MM. The only way you can really describe UPR stuff is "knock-off". I don't believe they do any really engineering for their products, just take what others are making and try and make it their own. May still be Ok, but you still lose something there compared to the original. There are others out there, I believe the one offered from PSR is supposed to be really nice.
    2003 Azure Blue Mach 1
    IUP - 5spd
    18" Black Saleen Rims
    245/40/18 Front 285/35/18 Rear
    Bassani Catted X-pipe
    Borla Cat Back
    C&L CAI
    PHP Spacer
    Meziere Electric Water Pump
    FRPP Aluminum Driveshaft
    MGW Orange Shifter
    Steeda 3 pt Strut Tower Brace
    MM Full Length Subframes
    MM Chrome C/C Plates
    MM Lower Control Arms
    H&R Race Springs
    Variuos MGW Interior Pieces
    Go with the MM.
    Flagstaff
    that coincides with others I have spoken to.
    thanks
    Senior Member Ruckus46gt's Avatar
    Luke AFB
    pa racing
    Super Moderator Gene's Avatar
    MM, no comparison
    Senior Member Torchmach's Avatar
    Phoenix AZ
    Another Vote for Maximum Motorsports! It is quality stuff, haven't heard anything good about UPR. I have had MM LCA's, and Full length Subframe connectors installed.
    Senior Member Ethan@S3M's Avatar
    Id go with MM, Ive had both in the shop and the MM is better quality.
    Quote Originally Posted by Ruckus46gt View Post
    pa racing
    thats what i have and its sweet. its the beefier road racing version and it only weighs 20#s.
    Quote Originally Posted by Lucafu1 View Post
    Any problems fitting?
