Opps....sorry, Guess not the best time to joke around.
Nothing worse when you cant get a car up and running again...especially when someone else controls the situation.
Friend had issues with DSS, but he owns an Evo. The shop took all sorts of pictures and measurements for DSS to review and they simply chucked it as not their issue. Friend got his money back and he was not willing to do extensive modifications too it and talk about mis-leading direct bolt on parts from them.
I would just throw the stockers back on...They seem too handle alot of abuse...but not sure how much abuse it can handle on actual slicks. ET Street isnt much of a problem for a hundred run or so. I got 450 runs out of mine, but with their DR's.
Anyways...best wishes.
[rubbing salt] my diff and upper controls are all fixed as of this afternoon.... [/salt rubbing]
Used to be TrackWhore 11.38 @ 120... wanted to try our best track, but I never felt confirtable there. Plus that last few times ive been messing around with Nittos. I wheel hopped from the start, all the way down to the 1000' marker !!! Not one run, but 5 back to back runs just hopping away. Id safely assume that I have weakened them, so not willing to take any more runs. Least the stockers can hold up to 1.5 short times. Best I got was a 1.568 short time...good prep, stock clutch at its peak and good DA.
Anyways, Slicks seem to really grip in any and all conditions, so not sure. Sonic Venum only ran on ET Street and put over 100runs in.
Dont do Solid ... IRS Squats perfectly.
Car is back together. Test drive went well. So hopefully the wheels will not fall off tomorrow and I will be racing on Saturday.
kick ass. very good to hear. see ya at the track!
Glad to hear you will be able to run Saturday, see you at the track.
Should be all set to go. I look forward to seeing everyone and not being the picture guy again.
