2006 Gt Battery Drains
Just curious if anyone here has experienced the issue of their battery going dead if their 05-06 sat for a while without being driven.
This happenned to me twice now in the last two months. I read on other forums after the first time I had this happen that this is not uncommon, and is being experienced by many new Mustang owners. Some say the Shaker stereo, if left on when turning off the car is the issue, however the last time (yesterday) my battery was dead, the Shaker had not been left on.
Also my driver side window lost it's calibration and will not re-calibrate after the recent battery drain. The window now 'bounces-back' when reaching the top of it's travel. I disconnected both battery cables for longer than 15 minutes and tried to re-calibrate, but it still bounces back.
I've had both things happen. The boucing back window is something that I had happen to me b4 the battery drained. But it's only happened like 3 times. I have a the shaker 1000, but it took my battery about an hour and a half of sitting there with all the electrical on b4 it drained itself.
How long does the car sit for before the battery drains? If it is sitting for several weeks without being run, then it is the parasitic drain of all the electronics in the vehicle draining the battery. If not, you might need to have a parasitic drain test done to the car to make sure that all of the electronics are going into sleep mode after the car is shut off.
Yes this happened to me earlier this year I went out of town for the weekend the car was in the garage and when I got home to start it the battery was dead. Had to jump start it and took it to the dealer they had no idea to why the battery died. The car was less than a year old when this happened.
It sounds like you have an excessive parasitic drain problem. It should not go dead over a weekend. When all of the electronics go into sleep mode, the current draw is measured in milliamps. It would take a couple of weeks or up to a month to drain the battery. I would take it back to the dealership, and ask them to perform a parasitic drain test. They should have techs on staff that know how to perform this task. Allso, have you put any electrical accessories on the car recently? Alarm, stereo,etc.
I had this happen on my 05, ended up being the cd player would start chaging cd's when the car was off.
dealer replaced deck
