Kenne Bell Two-Valve Mammoth Blower Kit Installation
Kenne Bell puts its boosted tusks into the meekest ModularsHorse Sense: Just a reminder, but when modding the Two-Valve 4.6 for 15 pounds of boost or more, besides the forged bottom end bits, you must also fit upgraded oil pump gears. Stock 4.6 oil pump gears shatter at high power outputs, immediately ruining your whole day. Triangle Speed Shop (www.trianglespeedshop.com) in Texas has what you need. Mammoth power also far exceeds the humble '96-'04 Mustang's fuel system, so you can count on replacing all of it as well. Finally, '96-'98 engines require aftermarket or Performance Improved cylinder heads found stock on '99-'04 Two-Valves to work with Kenne Bell supercharger kits.
a
Photo Gallery: Kenne Bell Two-Valve Mammoth Blower Kit Installation - 5.0 Mustang
Kenne Bell Two-Valve Mammoth Blower Kit Installation | Digg It | Add to del.icio.us
