Thread: Shelby Oil Pressure Gauge Installation
    Jan 2007
    I am installing a Shelby Pod in my 65 Mustang (289) and replacing the oil pressure switch which was originally installed with a CS mechanical gauge which I bought from Tony Branda. My question is how do I hook it up to the engine? Do I buy an adapter to screw in where the original switch was installed? Please help ASAP. Thanks.
    Rob
    Do you just have the line that comes off the engine? If so Like on the 5.0 there is and adapter that screws in and then attach the line to the threaded end..
    Jan 2007
    I do not have anything on the 289. Just the hole where the oil pressure switch came from
    Rob
    I'll take a picture of my 89 that has that set up, I had to ditch the sending unit when I upgraded to Real Gauges. The pipe is about 3 -4 inches long and then you attach the line directly onto it and your gauge.
    Here is a shot of the pipe and the braided line attached to it.
    Jan 2007
    Thanks for the info and great picture. I hooked it up just like that. Thanks again for the quick response and have a Happy New Year!
    Rob
    No Problem, glad to help!!!
