Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: Forged motor build +
    Dec 2009
    LUKE AFB
    Aeroquip TFE -8. It will not weep ever.
    http://www.summitracing.com/parts/AER-FCC0820/
    I have used ever other type of rubber crap and it all weeps.
    I have an aeromotive E-85 fuel filter. Stock Rails and the Ford 80lbs Injectors.
    Twin GT pumps with a KB BAP.
    I figure I would have to pay the premium price to run E-85. I will definately need the larger fuel line to keep DC in check. Hopefully, I wont need a BAP. I also found that aeroquip hose and fittings are cheaper on the aeroquip website. I have a parts list for a -8 line, fuel filter, Y-block -8 inlet 2 -6 outlet, division x fuel rails...the fittings holy crap the 90* and 45* bends are expensive. I priced out the reuseable fittings not the push lock...Still up in the air about those. I will need to adjust my choice from their race lite hose to the TFE hose. Which is more expensive per ft.
    Quote Originally Posted by Mystic544 View Post
    Nice build
    Would suggest getting rid of that OEM plastic intake...
    Bullitt flows great under boost but there are other better options out there now-a-days too! Lots of real nice custom fab high-rise units, Sullivan performance, BBK....
    Anyway, good stuff man!
    The plastic intake performs pretty well and has proven itself to make 600 hp with pump gas timing and boost levels on a few other 2 valves that this shop built. The car that made 575hp had a slow ECM because it basically stopped processing data after 5600 rpms, lol, but the intake did cork up a little on the top end. (The ECM didnt crash it just took too long to record info after a certain rpm and the tuner had to work around that) I replaced my ECM with a 2004 Mustang GT because it has the faster processor over my 2000 ECM so I shouldnt run into any issues. However, I am curious to see how the PI intake does. I should have a linear HP curve because I run a centri supercharger but if HP starts to taper off in the upper RPMs I will know that the PI intake needs to be switched out. That will be the only bottleneck since the 3.1 pulley and 10% overdrive will not put the vortech over its max rpm at my expected rev limit of 6500.
    More to come in the next week or two.
    If I do change it out I will most likely get the the TFS trackheat intake manifold. Going to stick with a longer runner design to keep as much low end torque as I can. The eldebrock is a great piece and has huge gains for what it costs but the torque curve moves from 4500 peak to around 5500 peak. I also dont plan on running 7k+ rpms which is where the short runner intakes really shine.
  2. #12
    Senior Member brentsSVT's Avatar
    Sep 2011
    surprise az
    damn, i need to get my kb on before you finish! lol
    2004 SVT Cobra, C&L, Pypes, SLP, B&M, Steeda, conservative 483rwhp @ 12.6 psi
  3. #13
    Dec 2009
    LUKE AFB
    Lol, yeah you do. Even your pullied eaton would have some trouble with my stock long block from a dig! My car cut 1.6 short times off of foot brake launches.
  4. #14
    Quote Originally Posted by Stanger00 View Post
    You can't use push lock with the TFE I have listed above. You have to use the TFE fittings. Yes they are pricey, but you can install it and forget about it. And it does not weep.
    Quote Originally Posted by SloSVO View Post
    My guess is PSRs old Dyno?? Do I win the cookie?
    Only if you share!
    Nice hood Stanger00, I dont think I have seen that one yet. Where did you get it from?
  6. #16
    Sep 2011
    surprise az
    Lol put some street tires on it and then come find me lol! Ill be ready. ;)
  7. #17
    Dec 2010
    Tonopah, AZ
    Stanger,
    What rollers are you going to send it across since the previous one no longer exist?
  8. #18
    my COOKIES!!!!! mine mine mine
  9. #19
    Dec 2009
    LUKE AFB
    Well, that takes care of that question about fittings.
    Quote Originally Posted by 1966PonyGirl View Post
    Only if you share!
    I got it from Cervini a few years ago after someone backed into my car in a parking lot...No note was left, dirtbags.
    Quote Originally Posted by brentsSVT View Post
    haha, never gonna happen. Closest thing to street tires on this car are 555r's...
    Quote Originally Posted by Nucworker View Post
    Stanger,
    The shop I bought the motor from is doing the tuning as well. I live in California now, I left Arizona when I was forced out of the Air Force last June. The shop is called Advanced Engine Development in Cameron Park CA.
  10. #20
    Sep 2011
    surprise az
    we should be neck and neck when done.
