Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: 2004 Mustang Cobra / E-85 / Whipple / Auto / Solid Axle
    Cool 2004 Mustang Cobra / E-85 / Whipple / Auto / Solid Axle
    For Sale 9 Second Cobra
    No Trades, No Parting it out, Wire Transfer, Certified Bank Check Only. Buyer is responsible for any shipping costs.
    $25,900 OBO. PM offers.
    2004 Oxford White Cobra
    Original Owner 16,xxx miles
    E85 Powered.
    Garage Kept. In rain one time.
    Who this car is for. The street strip enthusiasts who does not care about cruising at 80MPH. It is very comfortable at 55-60 with the 3 speed auto. 3:27 gears would make it even better.
    Here is how it works at the track. Drive in, Swap tires, burnout, those watching will make comments that the car will probably run an 11. Rip off a high 9 or low 10. Return to pits and the crowd arrives. They say the car is too quiet to run 9's. They ask what if you break. I tell them it's a street car it never breaks. Destroy a few trailer queens and drive home with A/C and the Mach 460.
    Engine
    OEM Long Block
    Gen 1 2.3L Whipple 3.5/3.25/3.0/2.75/2.60 Pulleys
    Billet Flow 4pc pulley set - New Bearings and a spare set of 4 bearings.
    JLT High Boost CAI 12" Filter
    SCT BA2400 MAF
    MSD Launch Control / Two Step
    Maximum Motorsport Solid Motor Mounts
    Reische 170 Degree High Performance Thermostat
    LFP Heat Exchange and Reservoir Tank
    LDC Cooling Mod
    Start-n-Charge 160amp Alternator.
    Fuel System
    Ford 80lb Injectors
    Kenne Bell FRPS disc
    Twin GT Pumps
    Fore Precision Hat
    40 amp Kenne Bell Boost a Pump
    MDMjr Fuel Pump Driver Module
    8 gauge wire from battery to BAP
    Aeroquip TFE -8 line from Fuel Hat to Stock Rails
    T fitting just prior to rails
    Aeromotive 40 micron E-85 compatible fuel filter
    Exhaust
    Stock Manifolds
    Steeda Catted X Pipe
    Flow Master American Thunder Cat Back with custom tailpipes to clear slicks
    Transmission
    Rossler Terminator 3 Turbo 400 3 speed Reverse manual valve body Ross-Lock Transbrake
    10" Ultimate Converter Concepts 3900 stall Torque Converter
    JW Bell housing
    JW Flex Plate
    Lokar Dipstick
    B&M Hi Tek transmission cooler
    B&M Pro Ratchet Shifter
    Trans brake and two step on same switch
    Lofgren SFI Trans Blanket
    CSR Catch Can
    Energy Suspension Poly rear trans mount
    Laurel Mountain Mustang Drive Shaft Loop
    Dynotech 3.5" custom aluminum drive shaft
    Speedo takes signal from right front ABS tone ring
    Suspension Rear
    Steeda Weight Jacket LCA solid/delrum bushings
    Steeda double adjustable UCA solid bushings
    Tokico rear shocks
    Laurel Mountain Mustang Battle Boxes Welded In
    2000 Bullet Rear Springs
    DTS 8.8 rear end with Mark Williams 9" ends. Narrowed to 1998 Width
    Custom Bracing by Darryl Smith Race Cars
    3:55 Gears
    Detroit Truetrac
    ARP Bearing Cap Studs
    TA Girdle
    Solid Pinion Spacer
    Miller Race Cars Anti Roll Bar
    North Race Cars Brake Bracket for stock calipers
    GT Rotors
    EBC Red Brake Pads - New
    Suspension Front
    PSR Tubular K member
    Tokico Drag Struts
    UPR 175lb 14" coilovers
    UPR Full Length Sub Frame Connectors
    Power Slot Rotors - New
    Speed Bleeders front and rear calipers
    Hurst Roll Control Line Lock
    Maxium Motorsports Caster Camber Plates
    Interior
    Corbeau TRS Micro Suede Seats
    MMR Seat Delete Kit
    Maximum Motor Sports NHRA legal 6 Point Bolt In Roll Bar with Swing outs. Powder coated black.
    G-force 5 point harness setup
    Custom Carbon Fiber auto shifter relocation kit
    PLX Devices M-300 Wide Band
    Auto Meter Lunar Boost and Fuel Pressure Gauges
    Auto Meter C2 Trans Temp Gauge
    3 Position Intercooler pump custom switch On/Off/PCM controlled
    2 Position Motor Fan Switch
    2 Position Trans Cooler Fan Switch
    Momentary Toggle switch transbrake/two step
    Two Position Toggle switch for line lock
    Analog Datalog Cable from Wideband to Xcal2
    Speed of Sound Gauge Pod
    Blue Raptor Shift Light
    Window Tint
    Other Info
    ABS and Cruise Control Deactivated
    ARP Wheel Studs
    Mini Antenna
    Tires Front Yokahoma - New
    Rear 28" M&H Drag Radials - New
    Slicks and Skinnies
    Convo Pro15 x 4 Fronts with 1" Baer Spacers. 26" M/T Sportsman Tires
    Weld Pro Star 15x10 6.5bs. 28" Hooiser Stiff Wall Slicks with 12 passes. Tubes and Rim Screws
    Car Cover
    Xcal2
    More Pictures Click Here
    Videos Click Here
    Feb 2009
    Peoria, Arizona
    wHAAA!!!! =O
    Has it ever been raced?
    Senior Member IansBAJ's Avatar
    Aug 2010
    Chandler,AZ
    Quote Originally Posted by ahawkins View Post
    LMAO good one.
    One of the cleanest cars I have ever seen!
    Super Moderator Gene's Avatar
    looks like a future raptor owner lol
    Quote Originally Posted by Gene View Post
    This would be a little more fun.
    Now that would put your Cobra to shame for adrenalin rush!
    Senior Member svtrichie's Avatar
    Phoenix, Arizona
    Are you allowing test drives???? Good luck with the sale.
    Quote Originally Posted by svtrichie View Post
    If someone is a serious buyer yes.
