National Parts Depot Reproduction Wood Wheel - How To Install A Wood Steering Wheel
Some Assembly Is Required When Replacing A '65-'66 Standard Steering Wheel With A Reproduction Wood WheelYou would think that replacing a '65-'66 steering wheel would be as easy as removing the old wheel and sliding the new one onto the steering shaft. If you're replacing a standard wheel, that's pretty much the routine. But if you're installing a wood wheel, as found on the Interior Décor Group (Pony interior) option, the procedure gets a little tricky due to the wood wheel's use of two horn ring contacts, which must be assembled inside the steering wheel collar with insulator "feet," screws, and springs.
Photo Gallery: National Parts Depot Reproduction Wood Wheel - Mustang Monthly Magazine
National Parts Depot Reproduction Wood Wheel - How To Install A Wood Steering Wheel | Digg It | Add to del.icio.us
