Results 1 to 10 of 15
Thread: Changing Engine Oil on a 2007 GT500
    Member 6-Speed's Avatar
    Apr 2010
    Cool Changing Engine Oil on a 2007 GT500
    Here is how I change the engine oil on my 2007 GT500. Although the details (oil type & quantity, drain plug torque, etc.) are specific to the 07 GT500, the same basic principles apply to any oil change.
    Here is a list of tools and supplies I use:
    1. 16mm Combination Box-end Wrench
    2. Metric Sockets: 16mm standard
    3. Torque Wrench - 3/8" drive
    4. Oil Drain Pan
    5. Funnel
    6. Oil Filter Wrench - Pliers type
    7. Oil Filter Wrench - Strap type (Large Diameter)
    8. Seven quarts 5W50 Full Synthetic Motor Oil
    9. Motorcraft FL820 Oil Filter or equivalent
    10. Sheet of Aluminum Foil
    11. Nitrile Gloves
    12. Ramps
    13. Paper Towels
    Caution: I don't advise changing the oil when the motor is hot to keep from being scalded by hot motor oil. I always allow the motor to cool down a bit.
    Here are the Oil and Filter products:
    Consult the owner's manual to determine the type, viscosity and quantity of motor oil used for your particular vehicle and engine type. The recommended oil viscosity (and oil type "Full Synthetic") is also imprinted on the engine's oil filler cap so there's no excuse for using the wrong oil.
    My GT500 takes 6.5 quarts of 5W50 Full Synthetic oil.
    Here are the tools:
    1. Drive the front tires onto ramps, set the parking brake and chock the rear tires.
    After shutting down the engine, I usually allow the car to sit for 20 to 30 minutes to allow the oil to return to the oil pan before draining.
    2. Place the drain pan below the drain plug and remove the drain plug (CCW) with a 16mm wrench.
    The production line workers at Ford must be amateur artists.
    3. Allow the oil to drain out into the pan.
    4. Wipe the oil off the drain plug and inspect the O-ring for damage; replace plug if damaged. Leave a film of oil on the O-ring.
    5. Re-install the drain plug back onto engine oil pan and torque to spec. The torque spec for my GT500's drain plug is 19 lb-ft.
    Wipe clean the oil pan area around the drain plug.
    6. Loosen the oil filter with the oil filter wrench. If this is the first oil change, be advised the OEM filter is torqued on very tight and a plier type wrench is highly recommended.
    Caution: The filter is located right above a frame structure, once the filter is removed a gush of oil will flow from the fitting and drip all over the frame. I fold a sheet of aluminum foil and place it under the filter to channel the oil into the pan. The filter will be slippery so keep a good grip on it as you remove it and be careful not to drop it into the already full oil drain pan.
    7. Inspect the oil filter receptacle to make sure the old filter's gasket did not remain affixed to it; otherwise it will certainly cause an oil leak.
    Then wipe clean the outer flange of the oil filter receptacle.
    8. Prepare the new oil filter by pre-filling it with clean oil; I usually fill it up about 3/4 full. This will help oil pressure build up faster on engine start. You can pre-fill the filter whenever it is installed inverted like on the 5.4L motor. Don't try this if the filter mounts to the engine at an angle or you'll have a mess to clean up.
    9. Then apply a thin film of oil on the filter gasket. This will help seal the gasket and make the filter easy to remove the next time. If you neglect to do this, the filter will be very difficult to remove.
    Before installing the filter look on its label for tightening instructions. Sometimes the instructions are printed on the oil filter box.
    10. Re-install the filter onto the engine receptacle and turn in a clock-wise direction until the gasket contacts the flange and stop. Then note the position of the filter (use label/printed characters for reference) and hand-tighten it as directed by the filter's instructions. Typically it is an additional 3/4 to 1 turn. For the Ford Racing filter it is 1 to 1-1/4 turns.
    What I like to do is hand-tighten the filter first then use a strap type wrench to apply just a tad more of a crank - perhaps 1/32 to 1/16 of a turn just to make sure it is secure.
    Wipe off any oil that dripped onto the frame.
    11. Remove the oil filler cap and pour in the oil until 6.5 quarts total is in the motor. Let me clarify that some of that 6.5 quarts was already used to pre-fill the oil filter. Use a funnel to keep from spilling oil all over the motor.
    On my other cars, I like to under-fill slightly (about 1 pint less than spec) to avoid over-filling, then I check the oil level at least 30 minutes after starting the car. It's always easier to add than to remove oil.
    Starting with seven quarts, I have about a 1/2 quart left over.
    12. Re-install the oil filler cap - don't forget this step otherwise you'll have a mess to clean up and perhaps even end up losing the cap.
    13. Remove the chocks, start the car, verify your oil pressure, and check for leaks under the car.
    14. Park the car on a level surface, shutdown the engine and wait at least 30 minutes for the oil to return to the pan. Then check the dipstick to make sure the oil level reads in accordance with the manufacturer's recommendation. For the GT500, the oil level should be between the two small circles on the dipstick per the manual. With 6.5 quarts, my oil level reads at about 3/4 of the way up the cross-hatched area of the dipstick. Add oil if needed.
    15. Record your mileage and date of service.
    16. Pour the used motor oil into containers and take to your neighborhood oil recycling center. My local Checkers Auto Parts stores takes used oil. Filters can be taken to hazardous waste collection centers.
    Good writeup. I added it to the technical articles on the homepage.
    Member rdrumm's Avatar
    Anaheim Calif
    One note... when going to the Dealer for service, they use a synthetic "Blend" for all cars.
    What do you think? This is what the dealer uses, and Ford must agree?
    09 Shelby GT500 #735
    Apr 2010
    Quote Originally Posted by rdrumm View Post
    The GT500 5.4 L motor requires 5W50 synthetic motor oil and that's what your dealer should use as recommended by Ford. I am not aware of a 5W50 synthetic blend motor oil.
    Senior Member 05mustangman's Avatar
    Jan 2007
    Surprise, AZ
    wow very good writeup! Thank you!
    2010 GT500 - Modded out the Wazoo. Tuned by Shelby American Motorsports. Las Vegas, NV.
    2003 Ford Lightning- Airaid intake, Bassani exhaust, Lakewood torsion bar, 2" drop shackels and a few more mods.
    Senior Member BLK03SVT's Avatar
    Scottsdale
    Fantastic writeup- thanks for posting! I'm ready for my first oil change on my 2011 and I'm on the fence as to what oil to use. This thread has me leaning away from the Motorcraft oil:
    http://www.teamshelby.com/forums/ind...raft-5w50-voa/
    A guy on the shelby site did some major research and testing on 5w50's and came up with this:
    Sorry hard to read but it's in the thread in the link above on TS.
    I'm also struggling with having the dealership do it and am thinking of doing it myself or having PSR do it like I have in the past.
    2011 Shelby GT 500
    Black/Black/Satin Black Stripes, Electronics Pkg, FRPP/BMR Suspension/Borla-Ford Racing Exhaust
    488rwhp/463rwtq bone stock
    Great Past Rides:
    2003 Mustang Cobra SVT Convertible- 302 Stroker & more- PSR Tuned, 2003 Mustang GT- Silver Coupe w/boltons
    1996 Mustang GT/SC- Paxton SC & Tons of Mods- SuperFord Mag Car, 1995 Mustang- Red w/boltons. 1968 Galaxie 500
    Sep 2009
    phoenix az
    nice write up and pictures to boot ^5 Ivan
    Jan 2007
    Surprise, AZ
    ive been using the motorcraft oil in the shelby for over a year. no problems at all. I dont no if that is the only oil approved by ford but i no mobil 1 doesnt make 5w-50 or its just REALLY hard to find. ive had sanderson do the changes on it and have been very happy with their service.
    Apr 2010
    Thanks ... glad I can contribute.
    Apr 2010
    Quote Originally Posted by BLK03SVT View Post
    The Motorcraft 5W-50 oil will provide adequate protection for your engine but the oil analysis I've seen have shown it shears down to a 40 grade oil by 2000 miles and a 30 grade by 6000 miles. I sent in a 1800 mile sample to Blackstone Labs a few days ago to see how it performed in my motor. If you use the Motorcraft oil, I wouldn't wait for Ford's recommended scheduled maintenance intervals to change it out.
    If you decide to change to one of the Boutique oils (Amsoil, Redline), I suggest waiting until your car has at least 3000 miles on it; that's what Redline recommends. Just be advised that many of these oils are not API certified, although they are tested to meet/exceed API certification standards.
    Personal experience combined with what I have heard/read about dealership oil changes gone wrong convinced me that doing my own oil changes is the way to go. If you must have someone else change your oil, just be aware of what type/grade and amount of oil they put in your motor, better yet buy the oil and filter and hand it to them; some dealerships just fill with what they're accustomed to doing and that's to use 5W-20. Then before leaving the dealership check the oil level - especially that it's not over-filled (best done after the motor has been off for at least 20 minutes) and that the fill cap is properly installed.
