Thread: Anyone have a high speed buffer?
    Feb 2009
    Peoria, Arizona
    times getting closer to me leaving for basic and i want to try to get my car clean and parked in the garage under a car cover but first i want to get these pesky paint swirls out. I already have the waxes and sealants i just dont have the high speed i need to make it happen. If anyone has one i can borrow or use it'd be greatly appriciated.
    Senior Member Rick Shopmier's Avatar
    Grand Junction, CO
    From my experience high speed buffers tend to make swirls especially on dark colours. I would use a foam pad with wax with a very mild cleaner. In the past I used Meguires #8 (mild cleaner/compound/buffable) then hand wax (no silicone). First I would get all previous wax off with a mild soap (Dawn Dish Soap) then clean surface and finally wax. If you store your car do not put any plastic materials directly on the paint and use a car cover that is waterproof (even in doors) since these usually won't allow fine dust to penetrate to the paint, a paint drop cloth over the car cover is ok(especially out side). I stored my new '70 Corvette for a year(while overseas) out-side under a car cover and plastic sheet, looked as good as when I put it away. Lots of better paint protection now than back then (no wise cracks).
    RACER00
    Feb 2009
    Peoria, Arizona
    these paint swirls will not go away though, so i was told hit with a high speed or wet sand and i really dont want to even attempt wet sanding i just know im running out of time!
    Clay Bar and Glaze. 3m Hand Glaze works well.
    Wash, Clay Bar and Wax in a straight line from front to back.
    Never use a circular motion!!
    I had a black stang in the early 90's with no swirl marks.
    Jan 2010
    Peoria, Az
    PM sent
    Senior Member BLK03SVT's Avatar
    Scottsdale
    I have a porter cable da you can borrow. You'll need to buy some pads though, as I'm out of those. Lemme know.
    2011 Shelby GT 500
    Black/Black/Satin Black Stripes, Electronics Pkg, FRPP/BMR Suspension/Borla-Ford Racing Exhaust
    488rwhp/463rwtq bone stock
    Great Past Rides:
    2003 Mustang Cobra SVT Convertible- 302 Stroker & more- PSR Tuned, 2003 Mustang GT- Silver Coupe w/boltons
    1996 Mustang GT/SC- Paxton SC & Tons of Mods- SuperFord Mag Car, 1995 Mustang- Red w/boltons. 1968 Galaxie 500
    Have you tried a dual-action polisher first, such as the porter cable? If not, I'd suggest starting there unless you are experienced with a rotary buffer. I've got both I'm willing to lend out, but I'm betting you can find someone closer to you with one. Do not wet sand your car, please. Not needed for swirls. If you do know how to use a rotary properly, I'd pick that up if you have bad compound swirl marks as you can remove them quickly and safely with the proper supplies and technique. Stay away from the glazes if you want to remove your swirls. If you have any questions, I'm happy to answer them.
