Thread: FS: Weld Draglite Slicks and Skinnies
    Senior Member TorchedMach1's Avatar
    FS: Weld Draglite Slicks and Skinnies Sold!!!!!
    Well I'm putting my drag setup up for sale. I wanna go with a new setup for the up and coming race season. There is still a lot of tread on both sets of tires. The rears are drilled and screwed and have tubes. Rears are 15x8 with a 4.5" backspacing and fronts are 15x3. Rear slicks are 28x9 M/T ET Drags, fronts are 28x7.1 Moroso drag specials. I will also throw in a set of 28x7.5 M/T Sportsmans. The Sportsmans do have some slight cracking, but I ran them just fine. They will also come with center caps and lugs/washers. I was pulling bottom 1.4x 60' on this setup!!
    SOLD!!!!!
    Feb 2009
    Peoria, Arizona
    Bump for a sweet set of slicks and skinnies, too bad im a broke b!tch or i'd get them.
    Price Drop!!!!! $500.00!!!!!
    Arizona's Fastest Mach 1
    11.14 @ 120 w/ 1.48 60'
    GO-FAST MODS
    Magnaflow O/R X-Pipe
    Magnaflow Catback
    Steeda CAI
    Torch Red JLt Intake Tube
    Steeda Tri-Ax
    Spec Stage 3 Clutch
    Built 31 Spline Rear w/ 4.10's
    Rear Upper and Lower Control Arms
    NX Wet Kit (100 Shot)
    SCT Chip
    Custom Tune by PSR
    Sep 2009
    phoenix az
    did you have to spacer these to put them on your car ?
    was just wondering if they would fit a 06
    Quote Originally Posted by trucker View Post
    I did have to use a spacer to put them on the front, but the rears where fine. Not sure if they will fit an 06. PM me and you can swing by and try them on to see if they would work. I have all the stuff here to do it.
    GO-FAST MODS
    Magnaflow Catback
    Steeda CAI
    Steeda Tri-Ax
    Spec Stage 3 Clutch
    SCT Chip
    Custom Tune by PSR
