Ford Mustang Scott Drake Enterprises Tank Armor 22 Gallon Fuel Tank
Get Extra Cruising Range And Corrosion Resistance For '65-'69 Mustangs With A Stainless Steel 22-Gallon Fuel TankIt's always beneficial when you can make improvements that aren't obvious at a glance. A 22-gallon stainless steel fuel tank, manufactured by Scott Drake Enterprises and available from Virginia Classic Mustang, gives your Mustang both cruising distance and corrosion resistance, which means no more fuel tank rust out if your Mustang sits a long time between outings. This is an easy retrofit that no one knows is there except you and your Mustang. We're also going to make this invisible modification safer with Tank Armor from Antioch Mustang Stable.
Photo Gallery: Ford Mustang Scott Drake Enterprises Tank Armor 22 Gallon Fuel Tank - Mustang Monthly
