Virgina Classic Mustang Steering Column Rebuild
![](http://image.mustangmonthly.com/f/techarticles/mump_1004_virgina_classic_mustang_steering_column_rebuild/32636238+ppromo_large/mump_1004_01_o+mustang_steering_columns+restoration.jpg)
Tighten Up Your Driving Experience With New Replacement Parts From Virginia Classic MustangFew things are more irritating than a sloppy, worn out steering column, which is important if you're really passionate about safety and driving comfort. We tend to ignore the steering column because it's a mystery to most of us, yet it is as simple as the steering shaft in a pedal car. From 1964-1967, Mustang steering columns consisted of a solid shaft to the steering gear, support collar and bearing, turn signal switch, steering wheel, and a series of rubber grommets at the bottom.inline_mediumwraptextright0032636238/techarticles/mump_1004_virgina_classic_mustang_steering_column_ rebuildmump_1004_01_o+mustang_steering_columns+res toration.jpgtrue
Photo Gallery: Virgina Classic Mustang Steering Column Rebuild - Mustang Monthly
