Results 1 to 10 of 15
Thread: Cnl cold air intake and predator tuner
    FOR SALE Cnl cold air intake and predator tuner
    This is for a 2005-2006 Mustang GT, . $450.00
    602-694-1875
    bump
    Bump
    Price lowered
    This is for a 2005-2006 Mustang GT, . $300.00
    Quote Originally Posted by kbldoc View Post
    Price lowered
    Sold the Mustang to purchase 2011 GT and kept the tuner and Intake
    Tune was uploaded back to factory so Tuner is Transferable.
    Will load tune in your car before you buy to show tuner is working properly.
    Combo New would cost over $600.00
    Fits 2005-2006 ford Mustang. MODEL # U7140
    Tuner works on both V6 and V8, Cold Air Intake fits V8 GT only.
    I will install and load tune for free if you like.
    What is the Diablosport Predator?
    The Predator is a state-of-the art, high performance tuning flash programmer in a sleek handheld design. Once connected to the vehicle, the Predators internal computer recognizes the vehicles PCM and automatically picks the proper tuning files designed specifically for that PCM. Inside the Predator's memory are the actual tuning files that optimize spark timing and air/fuel ratio curves. The transmission parameters are remapped to improve the shift characteristics such as shift firmness and shift points. Unlike other 'tuners', DiabloSport's programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery. DiabloSport engineers spend many hours on the dyno, street and track to ensure the tunes provided with the Predator are the best they can be.
    Dyno Tested Performance Tunes
    The Predator was created with one thing in mind, POWER!
    Average power gains are in the 15-20 RWHP range. The Predators additional power makes itself noticeable immediately with an increase in power that starts in the low RPMs and builds into a frenzy at the high RPMs.
    A Predator equipped vehicle will notice significant improvements in drivability. The additional power and improved shift patterns created by the Predator tune will yield quicker acceleration and better mileage, whether it is in town or out on the highway.
    The power increase in the lower RPMs will yield a better throttle response. The increase in MPG is a byproduct of maximized engine efficiency, the improved timing curve and air/fuel ratio creates a more complete combustion, i.e. the engine extracts more power from each molecule of gasoline
    U7140 Specific Features:
    Dual timing adjustment points (2000-4000 RPM / 4000-7000 RPM)
    Timing table (+10% / -40%)
    Dual fuel adjustment points (2000-4000 RPM / 4000-7000 RPM)
    Fuel table (+40% / -15%)
    Idle (+/- 20%)
    Global Timing adder -6 degrees /+4 degrees
    Raise Speed Limiter
    Rev Limiter
    Re-Calibrate Speedometer for Gear and Tire Size Changes
    RPM Shift Points, adjustable via MPH
    Cooling Fan ON/OFF Temperatures
    MAF curve adjustment
    Internet Updateable
    All standard DiabloSport Predator features
    Bump
    Bump
    Still for sale, Make offer
    Senior Member IansBAJ's Avatar
    Aug 2010
    Chandler,AZ
    is the c and l a racer version? also are you using a canned tune?
    Finally received my 2011 Mustang 5.0 and need to sale the 2005-2009 CNL Cold Air Intake and 2005-2006 Diablo Sport Predator Tuner.
    The original tune has been loaded back into the car so the tuner is open to be loaded into any 2005-2006 Ford Mustang GT or V6' The Cold Air Intake will work on any 2005-2009 GT.
    Originally paid 3 times as much, still like brand new.
    $200.00 TAKES ALL.
    602-694-1875
    finally received my 2011 mustang 5.0 and need to sale the 2005-2009 cnl cold air intake and 2005-2006 diablo sport predator tuner.
    The original tune has been loaded back into the car so the tuner is open to be loaded into any 2005-2006 ford mustang gt or v6' the cold air intake will work on any 2005-2009 gt.
    $200.00 takes all.
    602-694-1875
    killer deal!!!!!!!!!!!!!!!!!!!
