Intake Manifold, Carburetor Combination, and Ignition System Upgrade - 4 Barrels Of 5
Intake Manifold, Carburetor Combination, and Ignition System Upgrade - 4 Barrels Of 5.0L Fun Part 2
Our '85 Capri Gets An Intake Manifold And Carburetor Combination, Along With A New Ignition System.Last month we started a short build series on an '85 Mercury Capri; this month we're continuing with an intake manifold and ignition system swap. To bring you up to speed, we took what was essentially a stock 5.0L Capri and updated the brakes and rear axle with later-model Fox-body components.inline_mediumwraptextrightSummit Racing sells carburetor and air cleaner combos, as well as carb, air cleaner, and intake combinations. We chose the latter, and included in the value pack was this Summit open element air cleaner and Holley 600-cfm vacuum secondary carb with electric choke.28045027/tech/mmfp_1004_intake_manifold_carburetor_combination_i gnition_system_upgrademmfp_1004_02_+engine_upgrade +summit_air_cleaner.jpgTrue
Photo Gallery: Intake Manifold, Carburetor Combination, and Ignition System Upgrade - Muscle Mustangs & Fast Fords
