Well it has taken since 9. Lol BUT i had a dentist appointment, no beer till about half an hour ago, and the part didnt come in till 7. Now last question i got a new bearing since i was already in there and figured it wouldnt hurt got it pressed on and all put back together. now how can i fill the pumkin? on a 9" rear there is a plug to fill it back up and usually all you have to do it fill it up to the plug.. I cant seem to find the plug. on the back side there looks to be like a peice of metal welded into a small hole but the rear has never been messed with so this cant be anything.. Can i fill it from the pressure release valve? Not sure what else i can do. 8" rear end Fyi Thanks in advance!
Austin
quit whining and just fix it
clean the air vent pull the axle put in a new seal fill the rear end and be done with it
oh and don't forget to clean the brake shoes off
Yeah i got it done. Took it to the fry's around the corner and to work to drop off some loaner tools. Didnt see much but i guess we will have to see in the morning. The drive line felt much better tho.
I just put what do you call it? If you anal is leaking what do you San Franciscans call it? An Anal Plug? I think that is the term :P
